Question about HP PSC 1610 All-In-One InkJet Printer
Paper jam supposibly
Keep getting a message paper jam but there is nothing jammed. The paper feeds about 1/2 way and no printing takes place. The rollers are OK. The print cartridges are OK.
  • 1 more comment
  • malsueshaw Aug 17, 2008
    I am having same problem. Printer about 2 years old.
  • Anonymous Aug 25, 2008
    paper is feeding halfway through, then telling me i have a paper jam. when i clear it, it feeds again and gives me the same error
  • patchrally Nov 23, 2008
    after following that link and doing what it says-problem remains.. it seems like it is a memory issue or something...as it repeats exact same thing-is there a way to undo the memory or something.>??
  • 35 Answers
Hi...!
click this link below it would help to solve the paper jam issue
link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00265823&dlc=en&product=390315
Posted on Aug 28, 2008
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam message where there's no paper jammed - canon imageclass mf7280 laser all-in-one
If a jam is detected and no paper is found, this normally means that the paper was not feed out of the paper tray. Keep in mind, a paper "jam" can mean paper is where is it NOT suppose to be... or paper is NOT where is is suppose to be.
Aug 10, 2009 | Office Equipment & Supplies
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
My HP LaserJet 2430dtn Paper jam
Try this, make a print from the by-pass tray, does it go OK or jam??
If it jams then there is a problem with the paper feed from the tray.
If it jams then
1-check the drum and see if there is an image on it( you can put a mark on the edge to see if it's rotating, thus eliminating the drum unit)
2-same for the reg roller
3-check for labels ar foreign objects
Oct 08, 2008 | HP LaserJet 2430dtn Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
