Question about Nokia N73 Cellular Phone
My camera is not working properly
I need help about the camera on my cellphone.... it was not working good.. when i use my main camera the i had to press the capture button the camera will got loss.. it comes over to stanby menu...so that i have to click again the word camera to put it back.. how can i solve this problemm. if u know pls reply me or send me a message to my e-mail address ( nj2b2aljun@yahoo.com )... thank you for your great consideration..
    New Friend:
  • 101 Answers
The problem is with the switch near the camera button ..try to replace the switch. also check your slide cover of your phone.
Posted on Aug 11, 2008
The remote has stopped working for my DP 300 DVD player. I changed the batteries, and I have operated another remote successfully with the new batteries, so it is not the batteries
Try to check the battery terminal the one that is connected into the pcb it might be loosed. sometimes the lead that holds the battery terminal is not properly connected. or try to check the led sensor the one that looks like a bulb, in order to check it you must have a cellphone with a camera then point the sensor into your camera lens then press any button you will see in your cellphone monitor that there is a red light glowing that indicates that the remote is in good condition.
Jul 09, 2011 | Norcent Technologies DP300 DVD Player
Need codes, not sure if remote sensor on tv works
To know your remote sensor is properly working you should have a cellphone with camera, point the sensor to the camera lens then try to press any button then look in to the monitor of your cellphone, you will see a red glowing light in your monitor.
Jul 06, 2011 | Televison & Video
The remote just stopped working. (The batteries have been replaced).
The problem of your remote may be the battery terminal or the sensor,checking the led sensor without using a tester, you should have a cellphone with a camera, point the sensor of your remote in to the camera lens then press any button then look in to the lcd monitor of your cellphone you will notice that their is a red glowing light, if no. try to check the battery terminal specially the one that is connected in the pcb you should remove the housing of your remote then if properly connected try to replace the led sensor. Some advice, do not throw your original remote cause universal remote has limited function sometimes you cannot accessed the main menu.
Jul 04, 2011 | Toshiba SD-K760 DVD Player
Does not work
Hello
Check its battery contacts first. In remote controls, if battery contacts get rusted or dusty, proper battery connection will not occur. If battery contacts are good, check its infrared emission. You can check it with the help of a cellphone with camera option. Put the cellphone to camera mode, and place the remote control just one feet away from its lens, and push each button on the remote control. Eventhough human eye cannot detect infrared rays, electronic cameras can. If there is infrared rays emitting, you can see its image on the cellphone screen. If not, be sure that the remote contro is faulty. If there is infrared image, and still the device you wants to control does not respond; infrared sensor inside your device is faulty, and should be replaced. OK.
Jun 15, 2011 | Radio Shack (15-2147) Remote Control
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
The subtittles on the tv I cant turn them off and its really annoying to watch the shows with all the writting in the way I tried holding the subtittle key on the remote down but it doesnt work pleaseee...
Hello
The only way to turn OFF subtitle is, press the subtitle key on the remote control itself. If it doesn't work, either your remote's subtitle key is not working properly or your remote control may not be the orginal one. To check the working of the subtitle key; you must have a cellphone with camera option. Hold the remote control in fromt of the camera lens of your cellphone, after set it to camera option, press the subtitle key, and see if an infrared image falls on the screen of the cellphone. Infrared rays, comes from the remote control cannot be detected by human eye, but electronic camera can sense it. Check this. Sometimes the switch may be faulty. If so, you have to open your remote control and clean it. Clean its inside printed circuit baord, and inner key pad buttons with a soft cloth dipped in pure alcohol or medical quality turpentine. Never use hard solvents like petrol or thinner, as they will damage both the plastic cover and inner rubber parts. If these does not help you, you have to buy an other remote of same number. OK.
Apr 07, 2011 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
I hav a TFDVD 1973 LCD COMBO TV.THE REMOTE WII NOT OPERATE THE THE TV, BETTERY IS GOOD , THIS IS A NEW REMOTE RC-024
good day! i have read your problem, i teach some simple tips to check whether your remote control is working or not considering you have a good battery. 1st tip is buy checking it through you cellphone camera. turn on your camera and point your remote control on your camera lens the press any button on your remote. if your remot is good you could see some ligth flashing from your cellphone screen witch indicates that the infrared is working. if thereis no ligth at all the remote is deffective. if there is a ligth and still it does not work in your tv maybe the remote you have is no compatible with your unit or the sensor receiver itself of the unit is defective. i hope this will help you.
Sep 29, 2010 | Coby Televison & Video
HAVE PROBLEM
weel I suggest you select a main sim on sim menu. Put your simcard in the left side if you have dual sim slot then open the cellphone, go to menu and select sim switch, then select the main switch. it will automatically restart your cellphone. after that you wait and see good signal bar and your operator logo what ever it is. now its ok. hope it will help you......
Mar 08, 2008 | Nokia N95 Cellular Phone
Nokia N73 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
