Question about HP Office Equipment & Supplies
Printer is showing an E will not print. Have clean ink cartidge as shown on screen. Still will not print. On screen is showing window with words fatal error
  • 659 Answers
Remove the carts and then re-install them they might not have connected correctly make sure its clean in there too.
Posted on Aug 14, 2008
    Master:
  • 521 Answers
The inkjet cartridge may be faulty try changing them.
Posted on Aug 11, 2008
Clean print ink
Seems like the cartridge head is jammed. You can take the cartidge out and put the head for like 5 minutes in warm water then clean it gently with some tissue paper, hopefully this shall solve your problem.
Oct 01, 2013 | HP DeskJet 5740 InkJet Photo Printer
Black words don't print jsut colored words and images. ink cartidges full. mp830 canon thanks
I know it might sound comical but did you take the plastic off the bottom of the black cartridge. If you did it is more likely that the printhead is blocked perform a printhead clean in the maintinance settings on your printer.
Mar 13, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I installed the Canon i80 driver and the printer is recognised by my PC however when i try to print the i80 does all the actions but no ink is shown on the paper. I have checked the print heads and the...
I know it sounds daft.. i had this on a word document... although the text was showing in black it was printing in white. try changing the text colour to black... hope that helps
Jan 10, 2011 | Canon i80 InkJet Printer
The printer don work and it shows has no ink,but das have ink
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Oct 25, 2010 | Canon S400 InkJet Printer
Installed new blk ink cart and others are all o.k. Will not print black at all - if I use the color button or try to print from the computer in color, words come out very light and other colors are not...
I assume that you inserted an new OEM black cartridge. If you are using aftermarket of refilled cartidges, change to an OEM cartridge.
- Press on the printer
- Press of and select
- Press of to choose , or
- Press
- The machine cleans the printerhead and goes back to the Ready screen when finished.
If you clean the head 5 times and things don't improve, the printer should be serviced at a printer service center.
If you are using aftermarket or refilled cartridges the ink is typically not up to manufacter specifications and can gum up the printheads.
Oct 04, 2010 | Brother Office Equipment & Supplies
Epson cx6600 printing only magenta even with new cartidges
Try remove and shake the inks and reinstall it back in and test to print. If you have tried more than 4x with the head cleaning it might be your ink pads inside the printer is clogged. Is this still under warranty? You have to call Epson they might help you out with it.
Oct 11, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
Oct 06, 2008 | HP Photosmart 7850 InkJet Printer
Hp 7310 all in one
First check that printer is not set to print B&W. Open an application to print a page, for example Word. Chose print command from the file menu on top bar , the print window will open.
In the print window press the 'properties' button, and check tha printer is set for color printing.t
Once you are sure printer settings are not in B&W, read the following.
Even if it shows color at 75, the printer color level may had not been reset since the cartridge had been replaced, in this case the cartridge may be empty.
If the cartridge is not empty it still can be faulty (eg. ink insid is dry).
In either case replace color cartridge with new original one.
If after you replace the cartridge it still does not print colors, then color head is faulty, at this point consider having the printer repaired by a technician.
Jul 22, 2008 | HP Officejet 7310 All-In-One Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
23 people viewed this question
Seeker5211
Seeker5211
