Poulan Pro 25CC 2Cycle Gas Blower Logo
Anonymous Posted on May 01, 2011
Dont know what the oil gas mixture is suppose to consist of
Roy Cagle
Level 3:
President:
  • Poulan Master 1,545 Answers
  • Posted on May 01, 2011
Roy Cagle
Poulan Master
Level 3:
President:
Answers
1545
Questions
Helped
913335
Points
4781
Your manual (from Sears) states that your mix ratio is 40:1. You will need 3.2 ounces of Poulan "Pro" synthetic 2 stroke oil mixed in 1 U.S gallon of gas or you can mix 1.6 ounces of the oil in a half-gallon of gas. They suggest using the Poulan "Pro" brand synthetic oil. I do also. Synthetic oil significantly reduces wear, allows the machine to run cooler, and burns cleaner with less by-products and emissions. You can view a PDF file of your manual here:
http://www.managemylife.com/mmh/owner_manuals/133702/POULAN-Blower-Gas-1009868L?brand_name_search=952711923++
Testimonial: "Saved me a trip to the hardware store.....went to the manual and got all the information I needed."
  • Roy Cagle
    Roy Cagle May 01, 2011
    I am happy I was able to help you.
7helpful
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 • Echo Garden
How to start
i would drain the gas unless you know it good 50-1 mixture. Try starting fluid make sure its running to lean. once it starts up the idle
Dec 28, 2011 • Garden
1helpful
Never owned a 2cycle product and some one gave me a John Deere t105c trimmer but dont have an owners manual and dont want to pay $20 -$40 for one just to find out how to fill with gas/oil mixture. Can you...
You need two-cycle motor oil, do not use regular motor oil. Almost all two-cycle motors are designed to run on a 50 to 1 mixture of gas and oil. Look for two-cycle motor oil at any store that carries two-cycle tools like chain saws, line trimmers, etc. A good bet is Lowe's or The Home Depot. If you get the 2.6 oz bottle you have to add that to one gallon of gas to get a 50:1 mixture. Always read the oil bottle for correct mixing amounts and mix the oil with the gas in a separate container then put it in your trimmer.
Jun 06, 2011 • Garden
Need to know the gas and oil mixture for a Homelite 2 cycle weed wacker
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
DONT HAVE PROBLEM JUST NEED TO KNOW MIXTURE OF GAS/OIL FOR POULIN PRO 20 INCH
The correct mix is 40:1. That is 3.2 oz 2 cycle engine oil to 1 gallon regular unleaded gas 87 octane. Use ethanol free gas if you can. Ethanol will damage your fuel lines in time.
2helpful
I need to know the proper gas/oil mixture.
Hello. 40 to 1,or 8oz 2 cycle oil to 2.5 gallon of gas, or 3.2oz of oil to 1 gallon of gas. Joe
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
1helpful
4helpful
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
