Question about Dryers
Drier is working but there is no heat coming out. Please can you help? Thanks Sandy
  • gunningg Aug 11, 2008
    Thanks for your feedback. will follow through to see if your suggestions make the difference.
  • 869 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off turn dryer ON and make sure there are no kinks in vent tube thats attached on back of dryer.2nd,find the outside vent opening and feel for strong air flow.If you have any doubt that its not strong enough then,pull dryer away from wall....pull the vent hose off the dryer ,.....now dry 1 load on a 50-60 minute Timed Dry Cycle.If all goes well, you now know your venting has to be cleaned out.(The only 1out of 1,000 other thing to check is your lint screen ,make sure you can see light through it.) 3rd and final , is if after running for 60 minutes with vent un hooked and still it is not drying competly,than you have to replace the Split coils on the burner,I really can doubt that you have a thermostat out.If you need to know the stats of the Split Coil to Thermostat ratio my experience is 250 Split Coils replaced to just 1 thermostat. Please Rate This !!!!
Posted on Aug 11, 2008
SOURCE:
No heat coming from drum when spinning with our indesit idc75 drier can u help? looked for reset butten but cant find one can u please help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 15, 2011 | Dryers
Drier turns but no heat (electric drier)
dsd
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 30, 2010 | Maytag Dryers
My 1991 subaru legacy blows cool air when I apply brakes Thanks Sandy
if your losing your heat when your car comes to a stop Sandy,you need to check the coolant level in the radiator when the engine is cold,fill it to the top and fill the reserve bottle too.
Dec 25, 2009 | 1991 Subaru Legacy
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
I AM IN NEED OF A USER MANUAL FOR A lAVADORA CT600 WASHING MACHINE IN ENGLISH. THE MANUAL I HAVE IS IN SPANISH COULD YOU PLEASE HELP ME MENY THANKS SANDY
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 03, 2009 | Washing Machines
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore gas drier does not heat up
HI .Thanks for the question. the problem you have is with a thermal fuse, located at the ,of the dryer. pull away from the .remove the back panel. clean all the lint in the dryer. and the vent to the outside. the thermal fuse is located on the air duct. on the left bottom. of air vent a small plastic piece with 2 small blue wires. replace this part. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Dryers
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag Drier, doesn't turn, doesn't heat, but dings.
hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Sep 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
