Question about Panasonic Microwave Ovens
Panasonic microwave ne1446 fault 33 - Panasonic Microwave Ovens
  • eto1234 Aug 11, 2008
    Please check your humidity sensor inside, could be faulty
  • eto1234 Aug 12, 2008
    Reg : Fault 33 on Panasonic microwave NE1446:
    There is anyway I can reset the fault manually or it gets automatically reset by itself once fault is cleared.
May also be caused by deterioration of the lightbulb socket resulting in detection of increased resisitance in the light circuit. chack flickering of the bulb to confirm.
Posted on Mar 22, 2012
  • Panasonic Master
  • 9,174 Answers
F33 or F34 codes may be triggered by either excessive heat within the oven or poor grounding of either the temp sensor or the controller (DPU) board. Check the following:
a) Clogged air filter (not applicable to OCS models)
b) Obstruction of the exhaust duct or insufficient ventilation
c) Defective thermal sensor (should read 30 – 70 kohm in room temperature)
d) Grounding of the thermal sensor (possible oxidation)
e) Poor connection (oxidation) at CN4 connector (PRO-1 models only)
f) Poor or no ground at the controller (DPU) board – ensure that all screws securing the board are in place
g) Missing screw(s) that secure the escutcheon to the frame (OCS models only)
h) If all steps above check OK, the error(s) may be caused by defective controller (DPU) board
Posted on Aug 12, 2008
6ya staff
SOURCE:
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
HAVE A PANASONIC MICROWAVE WITH A H98 CODE THAT ISN'T WORKING. IS WORTH TRYING TO FIX?
That fault is the inverter. It has failed. Only Authorised Panasonic suitably trained engineers should attempt repair. All they will do is replace the inverter and probably magnetron as that may have been the cause.
Oct 22, 2017 | Panasonic Microwave Ovens
If the problem of "h97" "h98" accorded from keyboard of Microwave oven then what should i can do?
refer to:
http://www.applianceaid.com/microwave-fault-codes.php#panasonic
Sep 10, 2014 | Microwave Ovens
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Microwave Ovens Logo
409 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
