Question about Universal Battery Charger Charges Multiple Combination
Charger needed NEED SOME METHOD OF CHARGING ONE SONY NP-FT1 CAMERA BATTERY CANNOT FIND A UNIVERSAL CHARGER HERE IN SOUTH AFRICA
Can I charge my camera fuji jv100 on my laptop with a usb
No. The NP-45A battery needs a separate charger. If you need a charger, one source is
http://www.overstock.com/Electronics/Battery-and-Charger-for-Olympus-Li-40B-Fuji-NP-45/6042413/product.html
Aug 01, 2011 | FUJIFILM FinePix JV100 Digital Camera
Can i charge my sony w320 with the usb cord. cause my camera didnt come with a charger.
No, the camera does not contain any charging circuitry. Connecting the USB port will drain the battery even faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
The camera should have come with a charger. You might want to contact the vendor from whom you purchased it. In addition, there are several third-party chargers available at
http://www.overstock.com/search?keywords=sony+np-bn1+charger
Jul 13, 2011 | Sony CyberShot DSCW320 Digital Camera
Hi. i have a sony dsc w130 and it says use only with compactable battery only. i know why that, coz i charfhe it with a universal charger. i heve tried short circuit, and nothing happends. i bought a new...
It is important for you to know that the specified charger that it is supposed to work with has a special method of charging it as the battery is a very delicate one. That is why it is specified that you have to use a compatible charger.
When you use a universal charger, it does not charge the battery as the battery is supposed to be charged. This inflicts some minor damage on the battery and makes it impossible for the battery to work.
The compatible charger has a unique spontaneous way of emitting charges into the battery and the universal charger lacks this. So when the universal charger is used, it does not emit the right amount of charge into the battery.
The only way around this is if you can modify the charger or the battery in such a way that it might work. But then, you maybe damaging your camera. Instead, buy a specified charger.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Jan 24, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
I have battery charger model no.BC-CS2A during charging after 7 hours indicator light is off that what is this indication.and after indicator light off charging process do continue or...
When the light is off, its mean your batteries already full so charging process stopped automatically.
After usage and the battery empty again, you can recharge them and you'll get the light is ON again.
If this helpful, RATE please !
Jan 20, 2011 | Sony Portable Battery Charger for NP-BG1...
I have inherited a sony DSC-w100 8.1 megapix 3x zoom camera and have no charger or how to charge what code for the charger please I have 2 batteries sony G type NP-BG1 help please
I found a lot of chargers for this battery (and batteries too) by searching Amazon for "NP-BG1 charger". There are also cheap universal chargers, which will charge any of the small lithium batteries found in cameras and phones, on Amazon or eBay.
Dec 13, 2010 | Sony Cameras
Im trying to charge my sony np-bg1 battery with the digipower travel charger. from my understanding, in the user guide it says that when a battery is charging the light will be red. well i have the battery...
I recently purchased the same exact charger for the same exact battery....I had to slide the battery in backwards to align the positive and negative and then it should charge properly. If you slide it in the other way which seems to be the front side of the battery the light will automatically appear green same as if no battery was in the charger. This is because its not aligned to the positive and negative from the battery to the charger. Best Wishes!
Sep 01, 2010 | Digipower Travel Charger for Select Sony...
Dear all, After approx 1 year not using the Sony dsc w55 battery is completely empty and does not recharge after connecting to the computer with the usb cable which came with the camera. The camera was...
The DSC-W55 does not contain any charging circuitry. Connecting the camera to a computer makes the battery drain faster, since the camera must use juice communicating with the computer (even if only to say it has nothing to say). You need to use the supplied battery charger to charge the battery.
If you need a battery charger, here are some:
http://www.overstock.com/Electronics/Compact-Battery-Charger-Set-for-Sony-NP-BG1/4397985/product.html
http://www.overstock.com/Electronics/INSTEN-Compact-Battery-and-Charger-Set-for-Sony-NP-BG1/5938447/product.html
Aug 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
BATTERY
When it comes to this matter,If it isn't the snoy battery problem,then it must be the problem of sony camera charger.
For the NP-BG1 problem,you can refer to this website for help information.
Sony NP-BG1 , Sony NP-FG1 ,np-bg1 digital camera battery charger
Jan 06, 2009 | Sony Cyber-Shot DSC-W7 Digital Camera
Universal Battery Charger Charges Multiple Combination Logo
52 people viewed this question
Top Universal Electronics - Others Experts
Are you an Universal Electronics - Other Expert? Answer questions, earn points and help others
