Question about Jl Audio 1000/1 Car Audio Amplifier
Jl amp i am getting the amber light on with the blue light no sound dont no what could be up pls help
  • 631 Answers
The amber is the low impedance indicator and can mean that the impedance of the load is too low or there is an internal fault (shorted output transistors).
The blue LED indicates that the voltage is too low. This can be due to a bad connection or low battery voltage.You need to measure the DC voltage across the B+ and ground terminals of the amp to confirm that they're at or above 12v.
Let me know if you have any other questions.
Posted on Aug 11, 2008
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
Low voltage light on
is not gettin enough power
low volt light on
Jun 01, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
Jbl 1100w amp no sound
a couple of things , there are sometimes fuses at the uput stage internaly or it sounds like you have bown the output stage or output i dont ko if it would be orth repairing as this is the ost xpensive part inside
Jul 20, 2009 | Pyle BZDBP212 Car Subwoofer
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Jl audio 250/1 amp
This could be due to multiple things. First I would run a test light to the speaker leads of the amp as if you were running your speaker...it should light up and blink to the sound of music coming through. If no sound then most likely your RCA cables are bad or input jackets on the amp are loose and be shorting out causing the low light to come on. If you know 100 percent that you bought that amp in good running condition then most likely its something simple like the RCA wires are bad..Hope this kind of helps you out.
Feb 21, 2009 | Jl Audio 250/1 Car Audio Amplifier
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 amp not working
If I'm not mistaken, the blue light is the low voltage indicator. You need to confirm that the voltage ON THE POWER SUPPLY TERMINALS of the amp never drops below 11 volts. If it does, the amp will shut off. It's possible that you have a bad connection or even a defective fuse that's causing the problem.
JL recommends a 100 amp fuse for the amp. If you use a fuse that's too large and something goes wrong, the amp may be very severely damaged (possibly beyond repair).
May 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl 500/1
Nine times out of ten if the amp smells burnt it usuallly is. Your best bet is to hook another amp to your system and see if you get sound.
Jan 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
277 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
