Question about GE MiniCam Pro HO98756 Webcam
Need software i have the minicam pro 98756 but cant find the driver
  • mat666 Aug 11, 2008
    i downloaded the driver but it says webcam not connected
  • GE Master
  • 19,396 Answers
From this page you can download driver software and manual.
Please vote the solution appropriately.
Posted on Aug 11, 2008
  • Ginko
    Ginko Aug 11, 2008
    You need to extract software first, then you locate folder where you extracted software and run setup program. An install wizard will start. Keep camera usb unplugged while you install driver, unless required by wizard.
SOURCE:
  • 556 Answers
SOURCE: Minicam pro GE
For those interested in Vista see the following
From GE
http://www.jascoproducts.com/support/vista-certified-products.asp
This may provide additional information -- read this even if the message is not applicable -- it also contains information about non supported camera versions.
When I try to load the driver for GE PC Camera on my Vista operating system, it gives me the following message: Do you want to search for a driver?
Posted on Dec 24, 2007
  • 7 Answers
SOURCE: minicam pro cant find a driver to downlaod
http://www.driverguide.com. This site is a pretty reputable site, it as alot of ads for free membership, for a small fee you can go ad free. I just search for the driver you are looking for and it is available.
Posted on Mar 19, 2009
yooperbud
  • 8637 Answers
SOURCE: need software
Normal 0 GE PC Cam Drivers
http://www.jascoproducts.com/support/software-downloads.asp
Then
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Posted on May 31, 2009
  • 3015 Answers
SOURCE: MiniCam Pro HO98756 Webcam: I have a GE Minicam Pro 98756 that won't connect t...
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Posted on May 06, 2010
  • 3015 Answers
SOURCE: i lost my cd for my ge minicam pro 98756 and i nee...
http://jascoasia.com/support/software-downloads.asp#pccams
Posted on May 31, 2010
I lost my cd for my webcam, every site that I am going on says that there is an error, I tried every one, is there any site that I can get the software for my cam? all I want is to get my cam to work.
Software and Driver Downloads ' Jasco
https://byjasco.com/support/software-and-driver-downloads
Software-Drivers.jpg Unless otherwise noted, all software is compatible with ... 97769, GE Wired Dual Scroll Optical Mouse for PCs (Windows 95, 98, 2000 & XP) ... 98756, MinicamPro Laptop, zip file download link · PDF file download link ...
GE Home Electric Products, Inc. GE MiniCam Pro HO98756 Webcam ...
www.driverguide.com/driver/detail.php?driverid=1305789 GE Home Electric Products, Inc. GE MiniCam Pro HO98756 Webcam Free Driver Download for Windows XP, 2000, ME, 98SE - GE98756.rar. World's most ...
GE Home Electric Products, Inc. Camera Drivers Download for ...
www.driverguide.com/driver/company/GE_Home_Electric_Products/.../index.html GE Home Electric Products, Inc. Camera Free Driver Download ' Free Download General Electric Company ... GE MiniCam Pro HO98756 Webcam Driver.
GE Home Electric Products, Inc. Drivers Download for Windows 10, 8 ...
www.driverguide.com/driver/company/GE_Home_Electric_Products/index.html GE Home Electric Products, Inc. Free Driver Download ' Free Download General Electric Company drivers. ... GE MiniCam Pro HO98756 Webcam Driver.
GE 98756 MiniCam Pro - device drivers [FOUND 27.2.2017]
hardwaredata.org/index.php?driver=25935 GE 98756 MiniCam Pro last downloaded: 27.2.2017 - 2017 version. ... Using the driver installer professional computer software may very well be ideal strategy for ... GE 98756 MiniCam Pro Driver free driver download for Windows 8 Enterprise ...
GE web cam GE98756 software Google Search
Mar 21, 2017 | GE Computers & Internet
Need software for GE minicam 98756
Take a look here http://madrihaveli.com/ge-minicam-98756-software-2e896-9f8ad
Jan 10, 2015 | GE Minicam Pro 98756 In Box
Minicam pro 98756. windows 7. installed driver and have sound but no video. reinstalled driver and checked all connections. cam works on other computer with windows vista. have gone on line for any...
I had the same exact problem. The correct driver for the minicam pro 98756 version 2 are not found anywhere online.
However, the
98083 Minicam Pro driver will work with Minicam Pro 98756 version 2. I have just tried it out myself.
Here is a direct link http://www.jascoproducts.com/support/download-files/98083.zip
Feb 05, 2011 | GE MiniCam Pro HO98656 Webcam
Webcam drivers for windows 2000 for GE minicam pro model no 98756
hi,
download from here :
http://www.jascoproducts.com/support/download-files/98081.zip
Fosg2000
Feb 22, 2010 | GE MiniCam Pro HO98756 Webcam
I need to install my ge minicam pro 98756 but i lost the disk
There isn't a model listed for 98756 specifically, so you might want to try one of the MiniCam Pro drivers at:
Try to pick the one closest to your model number.
Good Luck!
Jan 24, 2010 | GE MiniCam Pro HO98756 Webcam
I bought the mini webcam but dont have the software its a minicam pro 98756 where can i download the software for free
www.ge,com
Click on Products & services, then consumer electronics, software and driver downloads. scroll down to GE minicam pro and download driver
Jan 17, 2009 | GE MiniCam Pro HO98067 Webcam
GE MiniCam Pro HO 98756
what is the vista version you have.
i can fid it fot u if u tell me the vista version properly
Jun 14, 2008 | GE MiniCam Pro HO98756 Webcam
Necesito el driver para windows vista
Apr 25, 2008 | GE MiniCam Pro HO98756 Webcam
GE MiniCam Pro HO98756 Webcam Logo
629 people viewed this question
Top GE Computers & Internet Experts
Damen Wong
Damen Wong
Ekse
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
