Question about Adobe Acrobat 7.0 for PC
Cannot open or update Acrobot
When i try to update or open Acrobat adobe I get a message saying that the URL is not allowed and this number is displayed 1529,305,68,07785
Can you help please
Regards
Billy Morrow
    New Friend:
  • 11 Answers
Contact customer service for acrobat..
mayb its not an original
Posted on Aug 13, 2008
SOURCE:
Adobe Reader on ASUS laptop
PDF Repair Toolbox is a a new Adobe Acrobat file repair tool that allows users to fix PDF files which are inpdfible from Adobe's file recovery. A common error message from Adobie is that Acrobat PDF file format is having difficulties, the file is damaged and could not be repaired by normal means.
https://www.acrobatrepairtoolbox.com/
Jun 21, 2018 | ASUS Computers & Internet
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
How to Fix Adobe Acrobat Reader
Adobe Acrobat Reader needs to be updated. It sounds like your automatic update is turned off.
Mar 10, 2015 | Adobe Acrobat® 8.0 Standard Full Version...
Trying to open attachments using Adobe Acrobat Reader but keep getting error message { Adobe Acrobat Reader has stopped working ,try again later 523:523 } any one with any solutions gladly recieved.
One of the easies ways to fix this problem is to delete the adobe reader. Also remove from registry, if you do not know how to do that, stay away from it. Restart your computer and then reinstall the adobe reader, allow updates. Be careful, if your not then you'll also get the AVG tool bar installed. Read every install page and uncheck all other downloads EXCEPT auto upgrades. Hope it helps
Dec 03, 2013 | Samsung HP-R5072 50 in. Plasma HDTV
I need a serial number for adobe acrobat 9 standard
Locating Your Serial Number in Adobe Acrobat 1 Open Adobe Acrobat on your computer. 2 Select the "Help" drop down menu. 3 Select "About Acrobat" from the drop down menu. 4 Look in the lower right hand corner of the graphical dialog box for a 20 digit number separated by dashes every four digits. This number is your Adobe Acrobat serial number. Read more: How to Find the Serial Number for Adobe Acrobat on My Computer ' eHow.com http://www.ehow.com/how_5793106_serial-number-adobe-acrobat-computer.html#ixzz2HuL3UYak
Jan 14, 2013 | Adobe Acrobat® 8.0 Standard Full Version...
I updated my reader to v9 and now cannot open up
I have seen this before, First try rebooting your computer, if Adobe Reader has an erro trying to open a document once it will cause errors on every other document you try to open until the system is rebooted. If that does not resolve the issue you will likely have to uninstall then reinstall Adobe Reader.
Jan 13, 2010 | Computers & Internet
Adobe reader error message
It is possible that somewhere along the line adobe reader became conflicted with an update from something else ect.
First thing you should try is uninstalling adobe reader completely in add/remove programs. Then Install the latest version of adobe reader.
This should put an end to the error messages and restore functionality to normal.
Post back if you need any further help.Thank you for choosing Fixya!
May 27, 2009 | Adobe Acrobat 7.0 for PC
Cannot use reader 8.0,cannot remove it or install 9.0
oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
Dec 24, 2008 | Dell Dimension 8400 PC Desktop
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Adobe Acrobat 7.0 for PC Logo
54 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
