Question about Dell Inkjet 720 Printer
Cartridge slams Is there anywhere where I can go to see a schematic that would show how to attach the plastic strip?
  • 4 Answers
One end of the strip has an arrow and says "D-11". That is the left end of the strip. That is where the spring goes.
You begin by hanging the OTHER end of the strip first.
http://i34.tinypic.com/nlv7fc.jpg
It fits over a tab on the right hand endplate. If you look at the printer carriage, the back looks like an upraised hand holding something.
The strip threads thru the 'thumb' from right to left.
http://i36.tinypic.com/dqnqyx.jpg
The arrow should face down, which will make the "11" face upside down but the D will still look like a D.
On the left is where the spring goes. Here, there is a second tab which only locates the slot for the left side. It doesn't actually fasten the strip, it just passes thru the post. At first this confused me.
http://i33.tinypic.com/11qn8nn.jpg
Posted on Aug 15, 2008
When I turn the printer on the ink cartridges slam to the right of the printer and won't move again.
Most likely the encoder strip is dirty and the print cartridge can't tell where it is in the printer. If you look in the printer through the paper feed area you should be able to see a clear plastic strip running along the back of the printer that is attached to the print cartridge carriage. Wet a q-tip and GENTLY rub along the front face of the encoder strip. You should be getting black to grey material on your q-tip. Continue until the q-tip comes out clean. Take a dry q-tip and dry the water off the encoder strip. Turn on the machine and see if it figures itself out. If it does it would be a good idea to clean the part of the strip where the cartridge carriage was.
Sep 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
May 28, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Cant put printer piece back in
Try to print any document.
If this failed then printer cannot be repaired, if the printer is under warranty then Lexmark will replace the printer else. I am sorry to say you need to purchase a new printer
your's tech expert
Jeeth
Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Part FELL off!
It sounds like this is the is the position indicator tape. There should be a small hole on both ends of it that fits over a small plastic tab on eich side of the printer. It normally needs to fit in a small **** on the back side of the print carriage.
With the printer turned off & preferably unplugged, gently slide the print carriage to the center of its range of motion. Ensure that this plastic strip is still attached on the opposite end and it feeds through the back of the print carriage. There should be a small tab to attach the free end to similar to what you see on the other end. The strip should be taut but not tight enough to stretch and it should not sag. Exactly where the attach vary somewhat depending on make and model, but they are all similar.
Mar 22, 2009 | Lexmark JetPrinter Z515 InkJet Printer
I have an hp deskjet 3940 printer and the power light keeps flashing; moreover; the moment I turn on my pc, the inkcartridges slam from left to right.
There is a plastic strip that the cartridges move along with small positioning markings on it. When this strip gets coated with ink the sensors cannot read the position causing the cartridges to go beyond the end mark and slam. Unplug the printer power and open it to access the cartridges, use a cloth damp with water and clean this strip - BE VERY CAREFUL NOT TO DAMAGE OR DISCONNECT IT!
Jan 19, 2009 | Office Equipment & Supplies
Carttridge is slamming against side of printer, light is flashing, no printing, no paper jam
I suspect the problem for both of you is either the blockage of the position sensing path (a slot in the carriage) or the plastic band that is imprinted with many vertical stripes and lets the printer know where it is and needs to go is not where it belongs.
Open the printer as you would to change cartridges and look carefully with a flashlight inside for a thin ~ 6mm (~1/4") plastic strip and insure that it is clean and stretched between both ends. One end is normally anchored to the chassis, the other attached to a spring suspension.
Nov 05, 2008 | HP D1560 Deskjet Printer InkJet
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
X 1150
That's the "encoder strip" which tells helps the printer cartridges know where they are. It runs the length of the printer and runs through the cartridge carrier. There should be some places to attach it on either side of the printer, although you they may be difficult to reach without opening the printer by removing some screws.
Apr 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
