Question about Panasonic Microwave Ovens
My panasonic genius old as it is,suddenly stopped working turns itself off after 15 sec not heating is it throw it out or can it be fixed simply????
  • rgoodie1 Aug 12, 2008
    THANKS FOR THAT INFO. THE MODEL IS A GENIUS INVERTER. ANY IDEA COST OF REPAIR. COULD I DO IT MYSELF. i LIVE NORTH WEST AND NOT SURE HOW ID GO AT FINDING A REPAIR PERSON. THANKS FOR YOU ASSISTANCE.
    CHEERS
  • Panasonic Master
  • 9,174 Answers
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts here.
After you look into this, if you still need help, please write back with your model number.
Posted on Aug 12, 2008
  • William Miller
    William Miller Aug 18, 2008
    Do you have the model number?
    It will be on the tag and something like NN-S548BW, etc.
6ya staff
SOURCE:
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Microwave stops suddenly after 20 sec and no heating is obtained
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hdn
May 10, 2010 | Panasonic NN-T790SA Microwave Oven
heatman101
gsgf
May 01, 2010 | Panasonic NN-T790SA Microwave Oven
No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Panasonic Microwave Ovens
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
My panasonic genius microwave is about 4 years old and it just died is there any way of fixing it
my microwave started giving me notices to check the manual and would stop cooking the food. I turned the machine off, unplugged and looked at the back panel. Was I surprised to find the air flow vents completely covered in black dust. After wiping it up with a cloth and then a small toothbrush to completely clean out the air holes, the microwave works fine. What a simple solution to something I was beginning to think would be a major repair job. Surprise---simple is best!!
Sep 29, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
239 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
