Question about OKI C5510 MFP All-In-One Led Printer
Fuser reset / transfer reset
Can anyone help with the reset of the fuser and transfer belt?
How do you enter the diagnostics on this machine?
  • OKI Master
  • 4,338 Answers
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Posted on May 16, 2009
  • volkan keskin
    volkan keskin Jan 21, 2014
    at the same time I open the machine by pressing the up and down but does not open the menu said. we open the upper part of the machine?
    New Friend:
Reset video ?
Posted on Nov 20, 2012
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
Transfer belt warning on oki c3200. How do I reset
8. Restart printer.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Office Equipment & Supplies
Fuser temp
If you need to reset a heat fault. Press # * C * and the machine will enter diagnostic mode. Enter the number 14 , like you were making 14 copies. Press 1 and then start, Some machines will reset just pressing 14 and then start. But 14 is the number used to clear fuser heat faults
Jul 28, 2010 | Sharp Office Equipment & Supplies
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Toner will transfer to the transfer be
As I understand it from servicing laser printers, the toner is actually drawn statically to the paper from the drum by a charge on the belt. Toner is not supposed to be distributed to the belt. The fuser fuses the toner to the paper after the transfer. Can you access the fuser rollers to see if there is any sign of wear or damage they may be keeping the paper from entering it properly? The toner on the belt is probably excess from the paper not being pulled through and having the toner fused properly.
Dec 31, 2008 | Konica Minolta magicolor 2400 Laser...
Hp color laserjet 4700 etb reset
I have successfully reset the transfer kit life by entering the service mode then resetting the color page count to zero then powering off then on.  Hope this works for you too!
Jun 30, 2008 | Office Equipment & Supplies
OKI C5510 MFP All-In-One Led Printer Logo
2,976 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
