Question about Tag Heuer Watches
Setting Tag Heuer Formula 1 CAC1111.BA0850 to Zero Position
Could you kindly tell me how to calibrate my Tag Heuer Formula 1 (CAC1111.BA0850) back to the zero position. The long hand and the related counters do not return to the zero position when i try to reset it.
I would be most grateful for your help.
Thank you in advance.
Tos
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
  • 93 Answers
SOURCE: Tag Heuer Formula 1. I have set it and in 15 min
you can find a shop to repair<a href="http://warhammeronline.cheap-wow-accounts.com/" >cheap warhammer gold</a>
Posted on Dec 25, 2009
  • 2501 Answers
SOURCE: Tag Heuer Formula 1 with alarm WAH111A.RWV3350
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual"
Posted on Feb 10, 2010
  • 2501 Answers
SOURCE: cannot pull the knob out, to change the date and
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Posted on Mar 08, 2010
  • 22 Answers
SOURCE: my tag heuer carrera stop watch doesnt reset
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Posted on Sep 23, 2010
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have a tag formula 1 with a G10 711 movement. New G10 711 have a different size date ring. How can I (I am a watchmaker) find the correct movement?
remove dial - use engraving tool to remove 3 plastic knobs to remove calendar wheel. replace calendar wheel with old one then heat a small drill to remelt plastic in the 3 holes.
Mar 11, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
MINUTE HAND TICKING EVERY 4 SECONDS INSTEAD OF EVERY SECOND
If its a quatz movement - could it be that your battery needs replacing? This is a feature of my Tag 6000 so I assume yours is the same.
Aug 26, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
MY TAG FORMULA 1 WATCH KEEPS STOPPING AT 11.20 BUT THE SECOND HAND KEEPS GOING.
mcdevito75 here, It sounds like the (larger) minute hand is leaning against the (smaller) hour hand, stopping the time telling past 11:20 while the seconds hand keeps going. You"ll have to see a Watch repair person and have them look at your watch. Best Bet, look for a small watch repair shop in your area.
Aug 25, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I cant seem to find my instruction booklet. where can i get some info on my CAC1111
Go to the Tag web site "www.tagheuer.com/the-collection/tag-heuer-formula-1"
Select "men"
Select your watch and on the right you will see a menu,
select user manual and download.
Jan 15, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
My Tag Heuer's second hand sticks and jumps in 4 to 5 second increments
Has your display got a flashing display "BT" at the right hand side of the display? If it has, then it means that the battery needs replacing.
Jan 14, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Second hand sticks then jumps forwards about 5 secs keeps perfect time otherwise
1.Broken buy another one or
2. broken hand sticks but time works fine then don't worry about if time works.
Oct 11, 2009 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Early tag heuer professional 200m wrist watch
nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
Jan 25, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How do i remove links from band of f1
use a needle to push the pins out.it might take some time its not easy
Dec 23, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Open Questions:
Watches Logo
93 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
