Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Pip on d52w20
I can't get pip to work. Do I need another tuner? The manual doesn't help
When i was on digital cable my pip didnt work either. with sat, the box offers a pip feature. if you have basic cable or using an antanna the pip on your tv should work. maybe its just your cable or sat not allowing you to use that feature.
Posted on Oct 11, 2008
SOURCE:
I am using FRONTECH LCD TV BOX Model no JIL-0616 in with my pc. when i push PIP button it doesn't show a window on my desktop .i also tried by applying default settings ,but the problem was not not...
I am also facing similar problem. I see sometimes both TV and computer simultaneously, but dont know when it works or when it does not works. It is working randomly when i press pip button. Anyone know how to fix this? When it does not work, it says unknown resolution. I tried changing different resolutions but no use.
Aug 20, 2011 | Televison & Video
How does PIP work ? where does the signal come from for the second picture ?
PIP uses the signal from a second tuner to insert a small or split-screen image on the main image. Some TVs have two tuners but most PIP applications need a signal from a VCR tape or tuner (tuner must be digital since 6/12), a DTV box, or a cable box for TV programs. A DVD player can also provide a signal for PIP if a DVD is playing. However some TVs will not allow PIP if the signal inputs are through the HDMI ports.
Sep 22, 2009 | Televison & Video
Ilo problem
What I hear you saying is that your main television tuner shows lines only while the PIP is functioning properly. The PIP works by using a separate tuner from the main tuner of your television (like a vcr tuner). Since the PIP works then it appears that your main tv tuner is not working anymore. It will probably have to be replaced. I recommend looking at our online technician list for a professional near you.
Good luck :)
Jun 20, 2008 | iLO 3200 32 in. LCD Television
No picture
Without diagnosis I would bet on a tuner.. with PIP you have two tuners.  However, check all your cables, with any electronic equipment, we always first start with the simple things and work upward toward more complex possibilities.
Mar 08, 2008 | Samsung PCL545R 54" Rear Projection...
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
PIP
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
[email protected]
Dec 31, 2007 | Vizio L32 32 in. LCD HDTV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need help getting PIP to work
You don't have a problem except you need two tuners. You say you have a VCR, which this has a tuner. Set your VCR to TV and and start the PIP and choose your VCR as the second source. You will now be watching two different channels, one from the TV tuner and one from the VCR tuner. Also just to clarify, you should have the cable wire from the wall running to the INPUT on the VCR and then a cable running from the OUTPUT on the VCR to your TV to make this all work correctly.
May 24, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
