Sounds like 2 different problems here. The ac gets warm when standing idle, is most likely the under hood fan not kicking on when ac is on. This may be a fuse issue or a relay. When ac is on, the fan should be on all the time. Relay maybe in an electrical box under the hood. Unplug the fan and test for power with a test light to see if the fan has power when ac is "on".
The inside fan not working on levels 1& 2 is likely the voltage ballast issue. this is an electrical block which controls voltage to change fan speeds. Usually found under the passenger side dash, right in the air flow comming from the fan and inside the air flow housing. Usually held in by 2 or 3 screws with a connector and 3-4 wires sticking out. this should be under $20 to buy and quite easy to change, if you can find it. Try behind glove box etc. Do not test the new one without it being in place, as it may burn out very quickly without the air flow to cool it.
Good luck
