Laptop Monitor keeps going blank or near blank. When the monitor is moved into a different position it may turn back on or it may not.
    Novelist:
    Scholar:
  • 125 Answers
Sounds like the back light of the screen is playing up or there is a loose wire. Either way the screen will stop completely and will not keep working. The best thing to do is try and buy a new back light for laptop screen and replace it, or take it to a professional to look at and repair for you. It's not a simply fix. Thanks igi_57!
Posted on Aug 11, 2008
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
Nec monitor LCD1560V
Try changing the resolution of the screen. Right click on an empty area of the desktop and select properties. Now choose the Settings tab and try adjusting the slider for resolution and click on APPLY. The screen will go blank for a few seconds and will show up in the new resolution. If you find it satisfactory, click OK to keep it, or click NO to go back and try a different resolution.
You can also go into Control Panel and check the monitor properties from there.
Hope that helps!
Oct 21, 2008 | NEC Computers & Internet
Dual monitor setup
Assuming you are using Windows Vista:
All you have to do is connect your laptop to a monitor via a VGA port (located on either the side or at the back of your laptop - it's the port with about 15 holes).
Once connected , you will need to configure how your 2nd monitor will function - as an extended or duplicate monitor. To set this you will need to go to Display Settings > and select your option.
Sep 28, 2008 | Compaq Presario 700 470024-192 Notebook
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Monitor randomly decides not to display
The problem is dry solder on Invertor board.Resolder all Invertor transistors and transformer.
Oct 28, 2006 | BenQ FP767 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
