Question about Electronics - Others
Iomega 250GB external hard drive. DHD 250-C
I have had this drive for some time and although it is about 3/4s full with data it has had very little use. It apears to be working as normal, clicks at start up and the blue light flashes, it shows ok in My Computer disc drives. The problem is I now get a message that the drive is not formatted and I'm unable to access any data. I ran a file recovery program on it and recovered most of the data but not all. Have you any idea how I can get the drive to run again without formatting it?
Thanks for now,
Regards,
Harry Reid.
harreid@hotmail.com
  • 26 Answers
SOURCE: Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Posted on Apr 29, 2008
  • 70 Answers
SOURCE: format 4gb transcend flashdrive JFV10. " WRITE PROTECTED"
plug in pendrive right click on it
click on properties
go to tools
and click on backup now
Posted on Apr 20, 2009
  • 112 Answers
SOURCE: 16GB Flash Drive NTFS Formatting
Assuming Windows XP, try the following:
START / RUN... / <type> devmgmt.msc <enter>
Find your USB flash drive listed under "Disk Drives"
Right-click and select PROPERTIES...
Select POLICIES tab
Select "Optimize Performance" & OK
Now select your flash drive from MY COMPUTER
Right-click & select FORMAT...
Select NTFS and format.
This should take care of your NTFS problem but note the warning about safely removing flash drive.
If it doesn't work, run "compmgmt.msc" / disk manager and check for partition issues.
Hope this helps.
Posted on Jul 11, 2009
trivialbrian
  • 8 Answers
SOURCE: Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Posted on Aug 02, 2009
bob_computer
  • 3153 Answers
SOURCE: Simpletech pinifarina 500GB external drive - unable to access
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Posted on Aug 23, 2009
I just got a 250GB Iomega eGo external hard drive and my Vista laptop will not recognize it in my computer but it is displayed as a mass storage device in device manager. I tried to update drivers through...
You may assign a drive letter to it by going to Start
  • right click computer
  • Select Manage
  • Go to disk management
  • select the drive It may be displayed as Disk 1 or Disk 2 (depends on your confug)
  • Change Drive Letter
  • Assign a Drive Letter
  • It should display on your computer
  • If you have not data on it, you may format it by going to Start and
    • Select Manage
    • right click on the drive and select format it.
    Oct 30, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
    Manual or instructions for iomega 250gb external hard drive ?
    Desktop Hard Drive Silver Series Hi-Speed USB 2.0 User's Manual: View Online [HTML] ' Download [717KB zipped HTML]
    Quick Start Guide [PDF 439KB]
    Specifications
    Aug 16, 2010 | Iomega (33215) 250 GB Hard Drive
    Please send me manual of 250gb iomega portable
    USB Desktop/External Hard Drive User's Manual: View Online [HTML] ' Download [295KB zipped HTML]
    Quick Start Guide [PDF 564KB]
    May 06, 2010 | Iomega 33089 250 GB Hard Drive
    Solution CD for Iomega Network Hard drive 250Gb
    You get the drivers at Iomega.com and look under support to get your drivers.
    REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
    Mar 16, 2010 | Iomega 33089 250 GB Hard Drive
    Reformatted my external hard drive on accident
    If formatting is not working, means there is some problem in the data segments of the disk.
    thanks,
    saumya.
    Aug 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
    Electronics - Others Logo
    513 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
