Question about HP L1702 17" LCD Monitor
I have a problem with my hp 1702 please help!!!!
When i play a game i have a white box on screen which says "Input signal out of range" the white box moves round the screen which is annoying any then the screen turns off i assume into sleep mode. If i use any windows based programme this box dissapears and all is good PLEASE HELP
    Problem Solver:
  • 35 Answers
This means that your screen settings are not compatible with the game. like 16 bit color to 32 bit color. set the screen settings so that you can play. Display properties would let u adjust these colors.
Posted on Aug 11, 2008
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
I am trying to play my game. When I plug the when I plug the red,white ,yellow extention in the AV1 and go on input it does not work it says no signal and I dont understan why I would need signal to play a...
The input is not "seeing" the signal from your game---try another input and make sure connections are correct and the set is switched to the input you hooked up to(they are labeled on the back)
Nov 07, 2012 | LG 60pk200 60 1080p Plasma Tv 60pk200
Floating gray box that says input not supported
When do you see the grey box? When you are playing a game? If so, try changing the resolution on your screen through the Control Panel...personalization...the resolution scale. You may need a lower resolution in order for the game to be played. I used to get a box that said "signal out of range". It wouldn't go away until I lowered the resolution in order to play that particular game. You can always change it back to your original resolution. Did you have a message in the grey box.
Mar 20, 2012 | E-Machines eMachines Desktop PC
My pc says input signal out of range and ntldr is missing what do i do
Hi
No input signal is displayed on my computer screen means your monitors refresh rate has been set at too high a frequency
To fix this you need to start your p.c in safe mode(press f8 at start up)
On the desktop go to control panel>display properties>settings>advanced>monitors>th... change the refresh rate to the lowest ,normally 60hz, make sure the box is ticked.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 21, 2011 | HP Computers & Internet
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
We have purchased "Let's Ride Silver Buckle Stables" and installed it. The play screen has a pop up that says" Input Signal out of range", which is on every screen, so you cannot see...
1. If there is an options program that you can run for the game, set the video resolution to something your monitor can handle.
2. Since few programs have that option, you may right click on the icon, select properties, and select compatability mode. Force the resolution to 640 x 480 and see if that helps.
You are getting this error because your monitor cannot handle the resolution that the program is requesting and it's out of range of what the monitor can handle.
Jun 23, 2008 | Computers & Internet
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Input Signal Out Of Range
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
HP L1702 17" LCD Monitor Logo
402 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
