What types of computer problems are typically the most difficult to troubleshoot
  • 326 Answers
Id say hardware problems, unless you have access to test equipment sometimes you have to go thru process of elimination on the
cpu / ram / motherboard / harddrive etc.
been a pian for me in the past
Posted on Aug 11, 2008
How do i charge my mp3 player.It plugs into a usb port to download music but I cannot find a place for batteries.
Without knowing the model number of your player it is difficult to answer your question.
Players which can be recharged typically do so through the USB port. When plugged into a charger or computer, this type device should have a LED illuminate or lightning bolt appear on the display to show it is charging.
If nothing happens when it is plugged in to a charger or computer, then it may only operate on AA or AAA batteries and should display something when it's time to change them.
Oct 13, 2014 | Nextar Audio Players & Recorders
The value that determines the product of computer concepts
Computer Concepts b> Essentially, a computer is a programmable machine. It allows information, or data, to be stored quickly and easily. Computers and peripherals, such as printers, can be networked together so information can be shared and exchanged between them.
Types of Computer b> Computers are typically classified by their and processing power, although there is considerable overlap between the different types. Laptop or notebook computers are lightweight and portable, whereas desktop computers tend to be larger, more permanent fixtures. Servers, mainframes or workstations are larger computers typically used in commercial settings. Hardware b> Computer hardware is the term used to describe the mechanical, magnetic and electronic components of a computer system. The central processing unit (CPU) is the "brains" of a computer; it interprets the instructions sent to programs. Other hardware components include keyboard, screen and disk drives. Software b> Computer software is the term used to describe the programs that run on, and direct the operation of, a computer system. Software is written in a programming language by a programmer and typical applications include word processing, spreadsheets and databases.
Apr 15, 2013 | Computers & Internet
My mac cannot read my Samsung G3 Station
Yeah that does sound like a potential failure in the harddrive itself. I would advise taking it to a local computer repair shop that can diagnose the hard drive. They will tell you if its failing or not. Typically these diagnostics are free depending where you take it.
Also yes encrypting hard drives are good for protecting your data from unwanted access, however when you do encrypt it and then the hard drive starts to fail, it becomes very difficult for data recovery.
May 14, 2017 | Samsung G3 Station 2TB USB 2.0 External...
Cant fugure out where the crankshaft positioning sensor is. found something that could be it but it looks like i may need to remove the balancer. is this correct?
If your car has the 3.1 liter engine, it has two crank sensors. There is one behind the balancer, which does not fail often. The one that causes problems most of the time is in the back of the block, between the motor and transmission. It is held in place with 1 8mm bolt and is very difficult to reach. Alternator removal will aid in gaining access. It is typically not a visual repair, more of a feel type thing. These sensors are mid-block, front to back, and at crankshaft height. They also have a rubber o-ring that tends to stick in the block, making them somewhat difficult to remove even after the bolt is removed.
Sep 05, 2011 | 1998 Oldsmobile Cutlass
Si think that my EGR valve is bad or stuck and it is causeing it to run lean I think
pretty common problem. Typically the repair is not difficult, however paying for the new part may not be too enjoyable. usually around 200 dollars at an autozone type store. We typically sell used EGR valves for 50 dollars.
Aug 17, 2011 | Buick Century Cars & Trucks
My Gateway mt3418 has dead video card what is solution?
Typically, installing a video card will have to be done by the manufacturer. Finding this type of part, especially from Gateway, will be very difficult. Installing the part will be even harder.
Getting this fixed may be more than the actual laptop is worth.
Contact Gateway for pricing.
Mar 02, 2011 | Gateway MT3418 Notebook
Dometic fridge thermostat replacement.
tie a wire to old one pull out and tie new to it and pull through
Apr 24, 2010 | Dometic Refrigerators
Squeeky dryer
Typically what happens is over time the back drum supports wear out. Once they have worn thin the drum rides on the bare metal portion of the support and you get the "annoying" speek sound. Or if the supports are the roller bearing type, the bearing fails and it generates the noise.
Anyway, the supports or rollers are inexpensive to replace and not very difficult.
If you want to tackle the problem, let me know.
Good luck.
Regards,
Jun 22, 2009 | Frigidaire GLER331A Electric Dryer
How to find the Bios Battery or a part # for it.
Most laptops have 3V lithium button batteries, Some ThinkPads have them but they have leads attached to them. The most commonly used battery for both desktop computers and laptops are CR2032
The BIOS battery are sometimes easy to access and usually on the bottom of the laptop behind a panel that also houses the RAM or modem or LAN card. Others are more difficult to access and most likely under the keyboard.
If you can access a manual for your laptop, it will indentify the location exactly.
May 20, 2009 | Acer Aspire 5920-6727 Notebook
Computers & Internet Logo
641 people viewed this question
David Payne
David Payne
