Question about Sony DVP-NS575P DVD Player
Sony dvd player cant eject disk
Hi Ya
when I push eleject on my Sony DVP-NS575P dvd player, Locked is displayed on the sceen and the player display. I think my 2yr old daughter has been pushing buttons? how would I get the disk out
Cheers MIKE
  • 3 Answers
Sony dvp sr320 dvd player is working, but open buton then displayed lovked no open what can i do
Posted on Aug 19, 2012
Actually if all you want is the dvd, there is a plastic cover on the underside of the dvd player below the dvd tray. Open it from the tab like a door and inside the slot you'll see a little black lever that you have to move with a small screwdriver or something like that....then slide the lever over towards the power button. If you don't feel comfortable doing this next step please bring it to some one that is familiar withit or a repair shop !!!!!!!!PLEASE UNPLUG BEFORE MOVING ON!!!!!!!!! Now if ya wanna fix the "LOCKED" error and unplugging it doesn't help, you have to take the top case of the dvd player (six screws and slide it back.....the case might get caught on the plug on the back so slightly lift it above it. Then once you have the cover off, with the front of the dvd player facing you...unplug the connector that is on the left hand side of the dvd tray that connects to the circuit board with firm and straight up pressure.....pull (it is ok to pull from the wires, just grab in the middle). Now you might have to plug in the power for the dvd player with that connector unplugged but do so with caution!!!!!......if ya want just put the cover back on without the screws on and just press power a couple of times.....then remove the power cord from the wall, take your case off, reattach the connector.......you'll here it kinda snap back in, make sure you put the connect back on the same way, it really only goes in one way, the prongs are more to one side. then slide your cover back on making sure you lift the back of the cover over the power cord on the back and the put your screws back in and your done.......this should solve both your problems. I think my kid was messing around with mine too!!
Posted on Oct 27, 2008
  • 10,594 Answers
Let me try to help you.
1- Press Power to turn the set ON.
2- press STOP and EJECT buttons for Five (5) Seconds.
4- the message UNLOCKED will display.
Enjoy n have nice day ;)
Posted on Aug 11, 2008
Refuses to eject says locked
You have the child lock turned on. See page 28 of this manual.
Apr 22, 2013 | Sony DVP-NS575P DVD Player
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
I have SONY DVD player DVP NS575P and SONY 5.1 channel how can i connect the DVD player to Sony 5.1 channel speakers
check behind your sony Dvd player for the RCA inputs and fix in the provided RCA cables, match the red jack pin to the red port, white to white and the other end which has one jack pin connect it to your woofer 5.1 speakers. check carefully where to connect as its clearly indicated IN. Remember the remaining yellow cable should be for video signal and the same connected to the monitor for video display.
mathewagunja
Sep 15, 2011 | Sony DVP-NS575P DVD Player
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Is this dvd player a multi region dvd player?
Its Not But you Can Make It.
Just Take Out The Dvd And
1.Power Off The Unit
2.On The Remote And Hit Display, Top Menu, Clear, Power A Menu Will appear on The Screen.
3.Select option 2 (Drive Manual Operation),
than option 4 (Tray Aging Mode). The screen will show two input lines, each with 5 digits
4. Change The Top Line To 12450
5. Then 00000 On The Second Line And Press Enter
6. The Disk Door Will Open And Close A Couple Times
7. Repeat Steps 3-5 and enter both Codes As All 00000
A Long Process But It Works.
Hope This Helps.
Sincerely,
Michael Scott
Jul 14, 2009 | Sony DVP-NS575P DVD Player
I need to identify and replace the fuse in Sony DVP-NS75P
I think you are asking fuse in Sony DVP-NS575P DVD Player.
Its just next to AC wire connector and not ordinary glass tube type.
Locate it in below image of PCB of power supply board..
Mar 16, 2009 | Sony DVP-NS575P DVD Player
Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
Dec 03, 2008 | Televison & Video
Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
Nov 15, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Sony DVP-NS575P DVD Player Logo
580 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
