Question about Nokia N70 Cellular Phone
N70 Battery Issue
My N70 runs for 3 days in offline mode but as soon as it accesses network the battery goes down in 4-5 hours time without even making a single call.
Is it something to do with the network selection? Will updating version help?
  • maddy5581 Aug 11, 2008
    my nokia n70's battery is not working properly
    Master:
  • 382 Answers
Even when you run the mobile in offline mode you might use it for listening to songs or any other applications..So please check if the battery life stands for around two days to around when you choose the network selection..If not then better take you moobile to any Nokia service centre..!..
Posted on Aug 11, 2008
What is the problem with my mazda sting 160i 2002 model as soon as i use electrics like lights, wipers etc, the battery runs down. i've replaced battery, regulator and alternator 3 times already. It runs...
remove negative cable from battery, hook up a test light to the negative terminal. opposite end to negative on battery. start pulling fuses, when the light on tester goes out. thats the bad curcuit that is draining battery. wait about 3 minutes before pulling fuses. Good-Day!
May 13, 2014 | Mazda Cars & Trucks
My phone will not turn on even though the battery is full. When it does turn on it is offline? How can I get it off offline?
Let’s try some tricks out here, see if that helps us,
1.) Check sim reader if it is ok.
2.) Make sure that when you power the phone you select the right profile. It ask you how you want to work "online or offline". you have to select online.
3.) Finally if the above is not heading us to the resolution, then we might have to “Remove the Sim IC & make the jumpers to 100%”… not sure if you could do that without a help from a phone tech.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Nokia N70 Smartphone
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
Not detec signal
Hello am virginia I will try my best to assist you with your issue.
Try this:
1.- Try your SIM with a different Mobile (Just to check whether the SIM is working well.) If your card won't work, your provider may replaice it, for FREE.
Have you try this already?
1.- switching off your N70,
2.- removed Battery,
3.- taking off the SIM, and replacing it again
4.- and restarting it.
If noting works may be because a virus as well if you thumb drive was infected with a virus. I hope this not the case.
Was this helpful?
Jun 26, 2009 | Cell Phones
My Dell Inspiron 1520 seems to use a lot of battery power, even when the lid is closed, and nothing is running. Is there any way to save battery power, without going into standby mode, or turning off the...
How long does your battery usually last? If it lasts 2 hours or more, that's normal for a notebook computer. The standby mode and turning off of hard drives is what notebooks are designed to do to give you more battery life. If you have to have it on and available all the time without going into standy mode, you'll need to get used to charging it every couple of hours. If you want to get more battery life, try the following options:
1) have the display turned off when not in use (this setting can be changed where you set up your screensaver)
2) turn off the wireless function (if available) when not in use
3) have the computer go to standby mode after 10 or 15 minutes of inactivity.
4) lower the brightness of your display
All of the above assumes that you're getting a decent charge and can use the notebook unplugged for 2 hours or more. Naturally, over time, notebook batteries wear down and don't hold a charge as well as they once did. If your notebook is a few years old and you're only getting an hour or so on a full battery, then it is probably time to invest in a new battery. If your notebook is new and you are getting this short battery life, contact Dell for a replacement battery as yours may be defective.
One last thing about notebook batteries. They are designed to be charged up and run down. If you leave your computer plugged in to a/c power all the time while you are using your computer, this greatly speeds up the wearing down of the battery. Whenever possible, you should fully charge your battery and then run the battery down to 10% or less before plugging it back in. This ensures that you get the most battery life on a consistent basis.
Hope this help. Please take a moment to rate the solution. Thanks.
Mar 11, 2009 | Dell Computers & Internet
Buick park avenue 1994 check engine soon wants to die
Clean the battery cables. The cam sensor magnet on the timing gear is most likely defective. This would require the timing cover to be removed to fix.
Mar 05, 2009 | 1994 Buick Park Avenue
Battery goes dead in 24 hours even without use
DO YOU HAPPEN TO KNOW THE CODE TO UNLOCK THE PHONE WE HAVE?I WOULD APPRICIATE IT GREATLY IF U COULD HELP ME OUT....THANK U VERY MUCH.
Dec 21, 2008 | Samsung SCH-u340 Cellular Phone
N 72 network prablem
Could be an intermittent provider issue, not sure. You could be selecting somebody else's tower that your provider has banned.
I tend to blame phone's antenna or an amplifier (if it has such). I have had exactly same happened to me two weeks ago with AT&T - "no access" on manual mode, unstable, weak, come-and-go connection. What I did was:
1. removed battery and SIM from the phone and kept it this way for maybe four hours
2. put those back in, did NOT turn the phone on.
3. completely charged the battery, i.e. once indicator says "battery is charged" I would unplug and plug back the AC cord - it will begin another incremental re-charge, at I would keep doing it for at least another hour.
4. turned the phone on - strong connection.
You wanna try this?
Aug 05, 2008 | Nokia N70 Cellular Phone
VAIO VGNTZ150N Laptop battery runs down when not in use
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Apr 24, 2008 | Computers & Internet
Nokia N70 Cellular Phone Logo
89 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
