Question about Canon IXUS V2 Digital Camera
Canon digital ixus - 2.1 megapixel AiAF
Backpacking round Oz using Ixus . Fine for 10 weeks but has suddenly packed up. Refuses to switch on properly, lens wont open and makes whirring noise followed by E18 in window
Don
SOURCE:
t00nz
  • 4738 Answers
SOURCE: canon ixus 900ti digital camera 10 meg pix
Well, the first obvious thing is to get it repaired under warranty. But if that's not an option, here are some simple things to try for a camera that won't power on. They won't work for every case, but they're worth a try: http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on Dec 28, 2007
SOURCE: canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Posted on Mar 23, 2008
devocap
  • 201 Answers
SOURCE: Hi, I have a Canon
Hey there johans, the E18 error code indicates there is a problem with your lens unit or lens cover. It was probably the result of an impact of some sort, or you may have something such as sand or dirt jammed in the device. If you cant see anything to clear and clean away, try turning off the camera and restarting. If this doesn't reset it and allow it to function properly, then you will need to bring it in for service.
Posted on Mar 31, 2008
t00nz
  • 4738 Answers
SOURCE: canon ixus 500 turns on
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 25, 2008
josephmanoj
  • 71 Answers
SOURCE: camera showing e18 on screen
Hello Dear,
the zoom lens unit of your camera is strucked if it is in warranty carry it to the Canon Care Center if not then take it to a repair shop there are about 50% chance of camera repairs without replacing the lens unit if the technician is a good one.
Regards,
Joseph Manoj
+91 9352008418
Posted on Jul 01, 2008
WHAT IS THE CAPACITY OF EXTENDED MEMORY OF DIGITAL CAMERA IXUS 95IS
There is no card limit mentioned but as far as I know it support 32GB SD card. But in case of video capacity it supported only 4gb in a single clip.
Mar 14, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
Confused over which battery pack I need for Ixus 700
What are you confused about? This is the correct replacement battery.
http://www.buy.com/prod/replacement-nb-3l-li-ion-battery-for-canon-powershot-sd10-sd100-ixus/q/sellerid/16427119/loc/111/208166814.html
Mar 06, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Took photos without memory card in - can I retrieve them?
Hi there
You should have a USB lead that goes from the camera to the PC, just connect them up and let the computer install the new hardware, once done if it doesn't autoplay just look in computer for "removable device" just double click on it to open the device and then copy the pics to the PC.
Good luck and thanks for using Fixya!!!
Feb 13, 2009 | Canon IXUS V2 Digital Camera
Canon IXUS 500 menu problem
You can access these functions from Manual mode. Press the "func. set"-button and change the camera mode to "M"
Nov 05, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon
It is an excellent 10 MP compact camera. Still expensive when compared to similar models, but if you don't mind about the price it is a grat camera.
In its category is also one with the best image quality (Canon IXUS 85 IS test shots)
Here you find technical specifications: Canon UK
Canon IXUS 85 IS Review | Canon
Check:
Canon Digital IXUS 85 IS
Reviews: Canon Digital IXUS 85 IS
Don't forget to rate the solution.
Thanks
Aug 31, 2008 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Canon ixus 960 will not turn on
I have a canon Ixus 960 IS and it will not turn on. I have charged the battery, but it still does nothing. I haven't dropped it and it hasn't been wet. Thankyou for your help
Apr 04, 2008 | Canon IXUS 960 IS Digital Camera
Digital cameras
Page 46 of Advanced User's Guide:
Press Menu, select AiAF, set it to "Face Detect".
Dec 27, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75
1. Make sure you are holding the camera very steady when you take the photo.
2. Try increasing the number of pixels resolution to super fine. If this uses too much memory, invest in a larger capacity memory chip. (The one supplied with the camera has a fairly small capacity.)
3. According to the manual, the "portrait" mode softens faces, but there are other modes you can use.
4. Depth of field is pretty much WYSIWYG . Move back and forth and try with and without optical zoom until it looks right.
Dec 26, 2007 | Canon IXUS V2 Digital Camera
Canon IXUS V2 Digital Camera Logo
1,231 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
