Question about LG VX-8700 Cellular Phone
Lgvx8700 i press the camera button and it says camera start error
  • jsweaz Aug 15, 2008
    This is my 5th LGVX8700. I went through 6 LGVX8600s. This is the second phone that I've received the "Camera Start" error. On the first phone it occurred right away. I have had this phone for approximately six months now and just started receiving the error yesterday.
I went through 3 8600's and this is my first 8700 (refurb though). I am having the same problem with the camera. It started a few days ago, just once in a while. Now it is all of the time. VZ said to bring it to a tech at the store or swap it out for another. I read on another forum that the tech should try updating the Firmware to T87VZV02 (OR O2) not sure what he typed. I'm gunna give it a try. I hope it works!!! Good luck with yours!
Posted on Sep 21, 2008
What is error code 2 on cannon camera sx210is
You can try a hard restart:
  1. Put fresh batteries in the camera but no memory card
  2. Double click the on/off button so the camera turns on, then off;
  3. Press the button again and, hopefully, it will start normally.
If this doesn't help, call Canon tech support. E-series error codes indicate hardware or firmware issues that need professional repair.
Aug 18, 2014 | Cannon Cameras
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    What mean error code pixma printer mp 145 ( E 8) ?
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset
    5) Unplug cable power. (for MP145 / MP150)
    6) Turn Off Power. (for MP160)
    Error Code Message for Printer Canon MP145 and Canon MP160:
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 = The connected digital camera / video camera does not support Camera Direct Printing
    E14 = The Ink cartridges whose destination are wrong
    E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 = Failed to scan head alignment sheet
    E22 = Carriage error
    E23 = Paper feed error
    E24 = Purge unit error
    E25 = ASF(cam) sensor error
    E26 = Internal temperature rise error
    E27 = Waste ink absorber full or platen waste ink absorber full
    E28 = Ink cartridge temperature rise error -
    E29 = EEPROM error
    E33 = Paper feed position error
    E35 15 = USB Host VBUD overcurrent error - USB
    E37 17 = Abnormal motor driver error
    E40 20 = Other hardware error
    E42 22 = Scanner error
    Jan 02, 2011 | Office Equipment & Supplies
    The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
    If it is a Canon printer:
    Clear the EEPROM
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    button pressing
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    E8 Waste ink absorber full, or platen waste ink absorber full
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD over current error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    Nov 16, 2010 | Office Equipment & Supplies
    D40 "Error: press shutter release button again." Nothing happens.
    If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
    Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    E3 flashing wat does it mean
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    Direct Printing
    E22 Carriage error
    E29 EEPROM error
    3 times for Orange EEPROM reset.
    button pressing
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    May 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    DELETING PHOTOS ON OLYMPUS C-420L
    To format the card:
    1 Pressing the Erase mode button and the Flash mode
    button at the same time sets the screen to the YES/NO
    display.
    2 Press the OK button to start formatting (the Card error
    indicator blinks). Press the Erase mode button to cancel
    the mode.
    3 When the card formatting is done, the Card error indicator
    goes off.
    To re-format the card intentionally:
    Press the Erase mode button and the LCD monitor ON/OFF
    button simultaneously, with the power OFF, to set to the Yes/No display and then press ok.
    Apr 09, 2009 | Olympus Camedia C-820L Digital Camera
    If the screen states E3, what does this mean and how can I fix it
    E3-3 = Paper jam
    E4 = No ink
    E29 = EEPROM error
    Perform these steps to reset the EEPROM
    button pressing
    5) Turn off the printer.( it must be turn off)
    then turn it on again.
    Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    "lens error please restart camera"
    Hello!!
    Remove the batteries and keep pressed the power button for few seconds it will reset ur system!!
    Oct 21, 2008 | Canon PowerShot A470 Digital Camera
    LG VX-8700 Cellular Phone Logo
    172 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
