Question about Brother MFC-8460N Laser Printer
Document jam i sent one fax and after that it says document jam,i have checked everything still it doesnt work. now iam not able to use the scanner and copier unless this one is resolved.please help
    Problem Solver:
  • 19 Answers
Have you checked the underside of the paper tray? There are three places where a jam might occur and the last place I looked was under the paper tray - I didn't expect that one!
Posted on Nov 22, 2008
How do I remove a document jam?
It could be a false positive for the paper jam. Check and make sure all of your sencer flags in the paper path are working properly.
May 23, 2014 | Brother MFC-J470DW Inkjet All-In-One...
How can i fax from a printer
hook your phone line up to it.  Hit the fax button, set your document in the feeder face down, and dial a working fax #, and then hit the send or enter button.  Let the fax do its thing and voila fax sent.
Oct 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Same problem. Only when i am scanning or faxing it does this.
The left side hinge may be broken, or the sensor flag where you insert documents can be broken or jammed.
Aug 03, 2009 | Brother MFC-8860DN Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Copier quality
Most fax machines would have a resolution selector to vary clarity of transmitted documents. The same would also hold true for scanning jobs. I would discount the possibility of the power supply since everything works except for the quality of the copy/fax. If the printer still works OK (quality of print out) then it is the scanner's availability to copy that is the issue. With current prices of all in one printers (fax/scanner), purchase of a new unit might be more practical not only in terms of cost but in downtime.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Brother MFC-8460N Laser Printer Logo
122 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
