Question about Panasonic Televison & Video
DVD olayer displays fault code F498. How do I fix it?
    Brigadier General:
  • 6,966 Answers
Error code F498 refers to "failure to process digital communication" which refers to solder failure of connectors, PCBs, laser eye and other major component interaction. It is a fairly common Panasonic problem.
A logical course of action is to present it to an authorized Service Center for appropriate action.
Your alternate options are:
  • Try a reset. Unplug from the mains for 30 minutes, hoping that it is just a system's glitch;
  • open the unit and check for any cold solder, flexible cable connectors and other electrical joints;
  • seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 11, 2008
Where to but olay vanilla indulgence bar soap online in india
Hi Lydia,
Olay Soap is not available in India since the past 1 year since due to price fluctuations they have stopped stocking it. You can easily get Olay body wash vanilla indulgence online.
Shiju Raman
Mar 24, 2013 | Olay Body Ultra Moisturizing Bar Soap,...
Quantum fx
Check these codes: [0409 0225]
Jul 27, 2012 | RCA Televison & Video
Region unlock for LG DV480
If you have the LG DV 480 then try these steps
1 Turn the DVD player and open the disc draw, leave it empty
2 Press Pause
3 Type 0000
4 When the blue screen appears type "0" in the new region code
5 Press Pause
6 Power off the DVD player then turn it back on
It worked for me
Mar 15, 2009 | Televison & Video
Fault code F498 on panasonic VCR/DVD player HV-VHD1. DVD draw will not open.
as far as i understand, it is caused by dry joints - poor workmanship. Try taking the top off and pressing down on right-hand side the green circuit board with the dvd in standby. Then switch on. If that works then what i did was to take all the screws out and jiggle it then put all screws back except the one to the left of the board, next to the brown board. seems to work now. Tip found on another forum, no credit to me
May 04, 2008 | Panasonic Televison & Video
UNLOCK CODE TOSHIBA DVD PLAYERS
unlock code TOSHIBA D-VR7KC
Dec 26, 2007 | Televison & Video
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
May 24, 2006 | Panasonic PV-D734S DVD Player/VCR
Televison & Video Logo
692 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
