Question about Creda W120VW Front Load Washer
Creda excel W120VW
No lights, no operation, checked fuse in plug, inside on pcb board, brushes replaced within last year. Mains trip had tripped but when reset stayed on, no shorts measured across mains lead. door click
  • 67 Answers
The 3 things i would consider would be the interlock,on/off switch or timer, Just because the door clicks it does'nt mean the interlock is'nt faulty there is no test you can do to prove it apart from trying a new one. also the on/off switch can melt remove facia to gain access to the switch it will help if you also loosen the timer, which will also allow you to see if the timer has shorted where the black connector block on the top of the unit goes if there is a track blown you will need to change interlock aswell. GOOD LUCK
Posted on Aug 31, 2008
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Creda TVR2 trips on plug in
Possible that there is a short within the board or the circuit which needs to be probed with ISOLATION of the circuit one by one. This can be due to failure of the surge capacitor or the power supply section. Also this can be related to replacement of the program control module if the fault is isolated with the board.
Jan 11, 2013 | Hotpoint Washing Machines
I have a creda excel 1200 the other day the water started to come out of the door and it tripped the electric,anyway i now managed to drain some of the water out of the machine but now its still tripping...
Remove back from machine, dissconnect motor plug from motor, then turn machine on, if electric trips then you know motor is ok so place plug back into it, then do pump, and so on untile something is disconnected and fuse wont trip. Make sure you do not have machine connected to power supply while removing wires, also that wires do not come into contact with anything when disconnected. And dont remove Any earth wires
Feb 11, 2010 | Creda W120VW Front Load Washer
Washing machine tripping elec's
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Feb 27, 2009 | Creda W120VW Front Load Washer
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Dec 15, 2008 | Creda W120VW Front Load Washer
Re: Creda W120VW
is the machine on its own circut
Mar 29, 2008 | Creda W120VW Front Load Washer
Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom.
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Creda W120VW Front Load Washer Logo
135 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
