Question about Acer TravelMate 4000LCi Notebook
My laptop is dead set
My laptop has a problem before, my O.S won't not start so i tried to fix it by my self, i try first to change the cmos setup utility on boot order, i set it in cdrom 1st priority then after i restart it, its became dead and all indicated LED has not work, please help me for my problem. thanks
When you say dead do you mean nothing no light indicators no blinking curser with a black monitor? because if its completely dead then its the motherboard
Posted on Jul 26, 2009
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
Inspiron 1000 doesn't save cmos settings
Hi
As you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.
Try to use the new HDD with this old motherboard.
Or else you can seek help of Any Geek Squad or computer vendor.
In case if you have any more trouble do contact back in Fixya.
Thank you
Sep 05, 2012 | Dell Inspiron 1000 Notebook
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
When the system was booting i turn it of and when it started it was saying boot agent version 4.1.07.
Simply set your cmos settings as laptop starts press either F2 or delete button to enter setup try setting all correct protocols and save and exit setup if problem persist u may have damaged a hardware component and may need to carry the system to a certified computer technician to get it fixed.
Aug 28, 2011 | IBM ThinkPad T30 2366 Notebook
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Real time clock loses time even while running off of AC. So, I don't believe it is a CMOS battery issue? The model is Toshiba A135 S2276 running Vista Home (32). Also, I have the dreaded self-assigned...
If you once take bios battery out the password issue will be reseted , the time zone of the date and time settings will changed , set the correct time zone first after that set the present timing, the time zone will be available in the time settings window itself , try it you can definitely fix it.
Oct 30, 2009 | Toshiba Satellite A135-S2276 Notebook
Cannot get into 'Setup'
when upower up press
"del"
F2
F8
F12
F10
try above
then u can able to enter in bios
Apr 09, 2009 | Computers & Internet
Unable to log in hp compaq persario laptop
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 16, 2007 | HP Compaq Presario R4000 Notebook
Sturt up problem
smtime low cmos battery could cause the pc not to start
a defected cpu and / or ac adapter will do too
Nov 14, 2007 | Toshiba Satellite A15-S157 Notebook
Laptop cannot be opened completely
ps: check for RAM if installed properly
Nov 14, 2007 | Compaq Presario Notebook
Acer TravelMate 4000LCi Notebook Logo
243 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
