Question about AOpen Computers & Internet
I have a DVD-Rom / CD-RW but no drivers to put in my computer?
  • 326 Answers
Can you explain further please,
has this drive been fitted yet?
what windows are you using?
windows normally picks dvd/cd rom without having to install drivers
Posted on Aug 11, 2008
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
Ive bought a dvd rom rw cge-8527b but when i put a cd in (dvd movie or dvd rom nothing happens the disc turn and stop no sign of it the icon stays the same
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 27, 2011 | LG (GCE-8527B) CD-RW Burner
Hp dvd rw ds-8a1p drive driver please
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disk the drivers could be on it
hope this helps dont forget to vote
Mar 12, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
My cd rom in not on my computer anymore and will not read a cd how can i reinstall it
Try to visit the dell or cd/dvd manufacturer website and download the proper driver for the model of the cd-rw/dvd-rom drive.
Sep 26, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Dvd/cd rom drivers
try dell.com for driver downloads for your drive.
or uninstall it from your device manager and reboot and it might fix itself
Apr 04, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
When I put a cd r in my burner then press burn selection then it
Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
www.radarsync.com/
Dec 19, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Computers & Internet Logo
24 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
