Question about Apple MacBook Mac Notebook
Random Shutdown Syndrome
I think that my mac is suffering from the infamous "Random Shutdown Syndrome", what can I do???
It just shuts down for no reason sometimes, is this syndrome still around? What can I do to fix it?
Please help me sort this before it gets worse,
Thank you.
  • clarkleslie Aug 12, 2008
    Mine goes down every three minutes -- or more frequently. It started today. Never had a problem with it before. Got worse all day. APLCARE acted like I was the first person who ever had this problem. Help!
  • Anonymous Mar 10, 2009
    yes
  • 30 Answers
The Random Shutdown Syndrome (RSS) is caused due to the heating of the heatsink.
When the heatsink warmed up it expends, and causes the system to trip. Apple replaced the defected parts and fixed the problem, i guess not for all macs...
Posted on Aug 17, 2008
Unexpected shut down
Good chances this is a thermal shutdown. if this is the case, the computer is shutting off to protect itself from permanent damage. if your OS is old enough (Snow leopard, I think) then the system logs show what caused the shutdown. it will give a number. anything other than a 0 or a 1 are bad. if I recall correctly 1, 5, 13 are thermal shutdowns. Newer OS's don't seem to show these codes. and Apple does not publish their meanings.
Dec 11, 2013 | Apple 13inch Economy MacBook laptop Intel...
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
If you can't keep your laptop stable and on for longer period, and you're experiencing random shutdowns I'd say you're facing a motherboard problem. This failure is actually well known and hapens a lot with Toshiba and HP. You'll most probably need to repair the motherboard that suffers from the Maxim 1987 or Maxim 1532 power chip failure.
The repair process is fairly straightforward, but it isn't for the faint hearted. It requires a resolder of the tiny Maxim 1987 chip that should get your motherboard up and running again in no time. The other alternative is to go for a new motherboard, or just get a new laptop alltogether.
If however your laptop experiences random freezeups, and you notice that the DVD is slow at reading data, and especially if you experienced some random mouse and keyboard freezeups, then you'll need to repair the motherboard from a FSB chip failur, which causes these random freezeups, which is a bit easier to do but still a challenge.
Hope this helps
Jan 17, 2011 | Computers & Internet
Power mac g5 automatically shutdown
Check if its not overheating.
Also check your power settings
Feb 04, 2010 | Apple Power Mac G5 Desktop
Screen goes black turns off
You are experiencing RSS (random shutdown syndrome). This seems to often be due to overheating but there are other factors. Read this article http://support.apple.com/kb/HT1237 and see if a firmware update is available for your laptop. This will often cure your very issue.
Aug 27, 2009 | Apple MacBook PC Notebook
Shuts itself off periodically
If the period of time in question is reasonably consistent - say 45 minutes after powering up it shuts off - you could be suffering from an overheating issue inside the unit. Temprature sensors can override manual operation and shut the unit off to avoid greater damage (or even a fire) occuring. Have the TV serviced.
If you find it happens at random time intervals from cold this is less likely to be the case and it could be relative to the mains power supply going to the TV. If you suffer from 'dirty power' (power that dips and surges instead of giving a consistent voltage) this could also cause an automatic shutdown condition within the TV. This could happen at any time after the unit has been turned on. An unterruptible power supply (UPS) would help with that.
Aug 18, 2009 | Vizio L32 32 in. LCD HDTV
Shut down with no reason
It could be a overheating problem.Check the power supply.Or it could be a hardware problem may be the motherboard.I think you require a PC Tech to check the system completely.
Regards
Aug 08, 2009 | Computers & Internet
Before my computer use to get really hot and then my computer use to shut down. I think there is a problem with the fan. Today when I switched it on the apple logo will come with the sound when it starts....
there have been problems with MacBooks suddenly shutting down since the first Intel based MacBooks were made. It is called RSS. (Rapid Shut Down Syndrome). The cause of which I have learned in the following excerpt.
Since isolating the heatsink as the cause of the MacBook’s Rapid Sudden Shutdown (RSS), readers have isolated the specific part of the heatsink that is causing the problem, is actually the CPU thermometer itself. Essentially, the heatsink can expand during use, and comes into contact with the lead from the thermometer’s sensor cable. A short circuit results, and the SMC pulls the plug. Once the system cools down, the heatsink resides and the contact is broken. This also explains why sometimes you cannot immediately power the MacBook back on. The heatsink is still in contact with the metal lead.
Apple’s solution to this is to realign the location of the thermometer and cabling on the heatsink so that it does not short circuit. That is why the new heatsink is necessary. In the view of this writer, it warrants a public recall. Any user can produce easily the scenario that causes the MacBook to crash, even with pre-installed applications such as iLife.
My 2 cents,
Thanks
Fame !
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Random Shutdown
Toshiba's are notorious dust collectors, try blowing back through the air vents and some clever use of the vacuum cleaner on the intakes can bring it back to life. also check the RAM for dust and dirt on the pins and clean as required. USE ANTI-STATIC Precautions!
Feb 21, 2009 | Toshiba Satellite P30 P35 Series Notebook
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
Apple MacBook Mac Notebook Logo
713 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
