Hitachi RM 2500 Electric Shaver
Problem for Hitachi RM 2500 Electric Shaver
Not charging
By ilongga88 on Aug 11, 2008
The shaver was mistakenly plugged into a 220v. outlet while it was on 110v. mode
Best Solution
posted on Aug 11, 2008
Very Helpful)
Benimur
Rank: Guru
Rating: 88%, 3802 votes
It would be logical to assume that the charging circuitry is damaged. If you are considering a DIY (do-it-yourself), then pls determine the limiting resistor that reduces the 220 to 110. Thereafter check the diode, capacitor and regulator. The final output voltage of the charging circuitry is slightly higher than the voltage rating of the battery. It might also be worth your while to check if the battery will still charge (using an external charger or a multiple voltage adapter). Soon as the battery is charge, pls check if the motor will still run. Failure of either the battery to charge or the motor to run would make repairing the charging circuitry pointless and you might be better off purchasing a replacement unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hitachi RM 2500 Electric
Questions and Unsolved Problems for Hitachi RM 2500 Electric
Do you recommend Hitachi RM 2500 Electric Shaver?
Answer
Answer
I have a 280 that quit taking a charge after 90 days. The green charging light will not stay on for... (More)
Answer
MY shaver foil for Hitachi RM-1500UD is damaged. I want to know where can i get a replacement foil... (More)
Answer
Please advise, where can I purchase foils for Hitachi electric shaver RM-F1000. Address and... (More)
Answer
were could i get this product in hyderabad, andhrapradeshindiakindly provide the address
Answer
i am an owner of hitachi rm2500 shaver at kolkata,india and iwant to know about availability of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Shavers Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
