Question about Electrical Supplies
My honda motorcycle wont start
If i push it will'barely. but it wont kick start
    Brigadier General:
  • 6,966 Answers
Depending on the model/specs, it could be anything:
  • ignition - CDI, dirty sparkplugs, timing, high tension wire;
  • fuel - clogged jets in carburetor; dirt carb(s), filter, petcock, restricted fuel flow;
  • electrical - engine off, side stand switch, neutral switch, ignition switch.
Hope this be of initial help/idea. Pls post back the model, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 11, 2008
Honda 125 innova kick start problem
Picture a lawnmower. Pull the starter cable with the lawnmower on its side. Envision the movement being the same on the kick start. Removal of the cylinder housing requires removal of the starter arm. Many scenarios the arm connects to a gear with a bolt. Recommend bike shop. So as not to damage gear.
Aug 27, 2015 | Honda Motorcycles
Wont start, kick starter is stuck
You have either broken something internally in the gear box or the motor is seized. A quick way to find out is to pull your spark plug and attempt kick starting it without the plug in. There should be no problem turning the engine over easily. You can put it in gear and attempt pushing the bike to see if the engine turns that way. More than likely your kick start has broken something inside, whether it be a spring or bearing, something has locked down to not allow it to rotate.
Feb 24, 2014 | 2007 Honda ANF 125 Innova
Honda scooter push button wont work only if kick start
it may have dirty cotacts on push button pull apart ad clea cotacts and check spring
Apr 12, 2013 | 2006 Derbi Atlantis City 100
Honda motorcycle will not start
main fuse, spark plug are the first checks
Mar 09, 2013 | Honda Motorcycles
I went down 2yrs ago and now I tried starting the bike the engine wont turn over
the bike engine has become cold.ask someone to push from behind while you sit and try kick-starting it.do this for several times.if you have failed and want to end up then go to any mechanic.i think this will work.
Apr 28, 2012 | 2007 Honda CBR 1000 RR Fireblade
My 2005 Honda VTX 1300 R Motorcyle sputters and won't start with kick stand down, neutral light wont come on, I changed the plugs and cleaned off the ground wire.
sounds like a problem with the sidestand switch. look for the sensor located at the top of the sidestand,when up it pushes in a sensor.
Jun 06, 2010 | 2005 Honda VTX 1300 R
Neutral lite wont come out and bike wont start. only if you push the bike.
Bike will not start if kick stand is down and you are in gear. Will not start unless clutch is pulled in.
Do not understand light wont come out ... do you mean ON?
Oct 18, 2009 | 2003 Honda Shadow Slasher
Kickstart wont move
Make sure it is in nuetral before trying to kick or the brake will keep engine from spinning. Otherwise have some friends push start you that will let you know if engine is good.
Jul 25, 2009 | 1979 Honda CBX
Basicaly brand new cr25o mx bike wont start
Assuming you are using fresh gas. Check to see if gas is coming out of the line, if not blow back up into the tank and if that works there's dirt in the tank. Check the spark by removing the plug and kicking it over with the plug touching the engine, look for spark. If no spark, try a new plug, if still no spark, you have a stator problem. It wouldn't hurt to clean the air filter in any case. Good luck!
Jun 12, 2009 | 2005 Honda CR 125 R
Electrical Supplies Logo
212 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
