If you are using one of the older models of the Xbox 360, not the one of the "Slim" versions, make sure that the switch at the base of the Component/AV cable where it plugs into the Xbox is on the right correct output. If this doesn't work it is most likely a problem with the TV settings. Try using it on a different TV and see if that works.
If this doesn't work give me some more information and I'll try to help you out.
