Question about Dryers
Bosch Nexxt dryer WTMC6300US won't start; seems to be related to lint filter cleaning; washing filter helped once and blowing out lint filter cavity - chronic problem started just when machine out of warrantee. Now it just won't start at all; also cleaning moisture sensors didn't help Likely cause and what part likely needs replacement?
  • Anonymous Jan 02, 2009
    We have gone through the exact same steps steps as previous postings. We have had this dryer for just over a year and just over the warranty.
  • Thomas Norman Jr. Mar 06, 2014
    Just going back to my old posted problem to explain what the true solution was: The control board was bad. I gambled & bought a new control board (expensive), installed myself, and it solved the problem 4 years ago now. Bosch is such junk.
For some reason my display showed the ''key'' icon. I must have switched it to lock somehow...I went through the menu,switched it to off and everything works now! Hope this helps
Posted on Jul 03, 2009
  • 868 Answers
Check for a bad thermal fuse
Posted on Aug 11, 2008
My dryer runs for several minutes, then starts beeping and an error code E: 01 is displayed. I've tried unplugging it for 30 minutes, but that was no help. Any ideas?
This means that the dryer is not able to exhaust correctly. Often times this is caused by kinked or blocked vent behind the dryer. If that looks ok, the vent in the wall may need to be cleaned. In this case or in most a professional dryer vent cleaner would be needed to clean the dryer vent.
One last thing you can check is the lint screen. On Bosch dryers the lint filter will become clogged from the dryer sheets. Remove the lint filter and run water through it. If water runs through, the lint filter is good.
I know this unit well and can assists you with any repair related question you have.
Let me know
Mar 26, 2011 | Bosch Nexxt 500 Dryer
Hi I have got problems with my Bosch Classixx electric dryer It runs for a few minutes and then it stops I have cleaned the filter system etc and looks as clean as a whistle It seems to stop as it...
Clean the front under the lint filter has a sensor on the left near the lint pin. purchase a special long thin cleaner for vac from: All rand Vacuums 561-967-3575 GREAT
Sep 08, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Dryer gets warm but laundry doesn't get dry. Dryer stops after about 10 min of running and starts ''beeping''
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
Jan 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Lint filter not allowing dryer door to unlock
Try unplugging it for an hour.. Might reset it..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dryers Logo
717 people viewed this question
Top Dryers Experts
