Question about RCA 20F511T TV
Tv turns itself off
Followed by a bright white/rainbow colored circle in the center of the black screen. the tv also makes a loud clicking sound while this is happening. i have to keep pressing off for the television to power down, and sometimes will not turn back on. this normally happens when there is a bright flash on the screen, then it freaks out. i have my contrast set to zero as any seems to make it worse... i hate this tv.
please help me!
thanks
  • slowg2 Aug 11, 2008
    figures!
    if i open it up what should i look for? are there any fuses? can i replace the bulb myself if its going bad?
    Scholar:
  • 167 Answers
Hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Posted on Aug 11, 2008
SOURCE:
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I have a samsung model #HL-R4266W tv, It is making a humming sound, and has no color other than it being in black and white the picture looks fine, what could be the problem?
This tv design have a colors wheel in it,have humming sound or loud motor noises.The colors flashes Black&White or lost all colors.The colors wheel is dying and the causes.The colors wheel replacement are not a do it ur self project.Hire a tv Tech. to do it right the first time.Colors wheel sit way back close to the Light Projection Engine itself.
Dec 30, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Everytime i turn off the tv and turn it back on
Tries unplug,replug 1 hour later,tv should reset itself to factory setting.
Nov 18, 2009 | LG 42LC2D 42 in. LCD HDTV
A rainbow circle of color has suddenly appeared on the screen,
if there is a speaker near the set it will draw the color out
Jul 09, 2009 | Panasonic TH-42PZ77U TV
The t.v. has too much color
First set the color to 0, the TV should be in black and white. if there is a purple or rainbow color then your tube may be failing. Most default settings are when everything is half way(centered). If this dosen't correct the issue than there is an issue on your main board.
Mar 22, 2009 | Quasar SP-2722 27" TV
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
RCA 20F511T TV Logo
90 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
