I have a Fujitsu ASTA24LCC heat pump and it has stopped going, but is showing some form of fault code. Operation & Timer lights flash together twice then operation light flashes 5 times. What does this mean?
  • Anonymous Aug 23, 2008
    Exactly same problem happens during the night (second night now). Got it going again last night by turning power off at mains. Not really the way it should go?
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
  • ivarsa Sep 04, 2008
    Another way this can happen for me it seems is, if it is frosty outside and I crank up the heating by 3 or 4 degrees the unit trips out. Turning it off at the mains and waiting a while before attempting to restart did the trick this morning. Don't bother to ring Fujitsu for information - you will be wasting your time!
Fujitsu Inverter ASTA24LCC has flashing "Operation" and sometimes "Timer" lights. I have cleaned filters but the lights still flash. Does anyone know the issue here?
You may need to open the louver and hold down the Manual/Auto button for 10 seconds to see if you can reset the machine. Additionally, unplug the unit for 30 seconds or so and then plug back in.
Dec 09, 2012 | Heating & Cooling
Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Jun 20, 2012 | Fujitsu Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Heat pump won't start, red light flashing
I do warranty work for Fujitsu ACs. You need to be more specific with the "Flashing" How many flashes of both the timer, and operation light are there? These relate to problems/faults. Take note next time and post it back here.
Feb 27, 2010 | Fujitsu Heating & Cooling
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
1,763 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
