Question about Philips GoGear Flash MP3 Player
Screen My Screen Went Out And All It Says Is "Wait for USB Connection" I Dont Know What To Do
  • tmacwiluvu Mar 05, 2009
    When i turn on my go gear it does everything good untill after te go gear sign then it says wait for usb connection and then when i connect it to the computer the screen turns blue and nothing shows up
My screen says the same thing i turn it on an everything starts off fine then after the go gear logo it says(wait for usb connection) i would realy like to fix this problem only had it a few days an got it as a gift
Posted on Sep 09, 2008
My screen went out and just both it for a month.I sont know what to do
Posted on Aug 11, 2008
SOURCE:
Gateway webcam
Dear Tori,
Greetings from New Zealand! You have not supplied much info - so we'll start from the beginning...SAFELY Remove web-cam connection - (I presume it is a USB connection?) - by R-clicking on the little icon - usally green - in the systray by the clock, & following instructions. Have you installed the web-cam "driver" software from the cd that came with the web-cam? If not then do so. Plug in web-cam USB & wait until pop-ups notify you that web-cam device is detected & ready to use. L-Click on "START" > All Programs > Web-cam program.
If this option does not work/is not available, then OPEN "My Computer" & click on web-cam icon. This should start web-cam software & you SHOULD see your smiling face on screen!
If Nothing works - then you will have to make a note of the model & contact Gateway for support.
I hope that this helps! GBU! - Bruce.
Apr 28, 2013 | Gateway Computers & Internet
My HP Photosmart B110 Series wont scan to my PC. The window kept showing that its necessary to update LCD screen? I dont know what it meant and I dont know how? Please help!
1) Leave the computer on with Digital Imaging Monitor
2) Turn off the printer
3) Disconnect the USB cable
4) Wait for 3 minutes
5) Turn on the printer
6) Wait 3 minutes for computer to update the printer
Regards,
Shrey
May 30, 2011 | Office Equipment & Supplies
I pressed the hd option in the set up menu and the screen went blank and a message no signal came up. any suggestions
First please excuse my english...I had the same problem and manage to fix it. Just remember that nothing is broken, the problem is you dont see what you are doing. First unplug your nbox and remove sd card or usb disk. then folow thease step. 1-plug the unit and press power. It is not possible to know if the unite is on... 2-press enter 3-press the down arrow 7 times 4-press enter 5- press left arrow 6- press enter. if it dont work try again and again. You have to undo what you did and put the unite back on the good setings. good luck
Jan 02, 2011 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
Connect to usb?
i cant conet to usb i need one driver
Apr 29, 2009 | Philips GOGEAR SA6045 MP3 Player
PSP USB connection- screen reads please wait
there might be somthing wrong with the hard drive or with the usb
Mar 31, 2009 | Sony PlayStation Portable (PSP) Console
I turn on my sansa e250 it goes to refresh database, then blanks
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Mar 30, 2009 | SanDisk Sansa e250 MP3 Player
My sony walkman froze i put it on the charger getting videos on
Just Wait for the battery to run out or hit the reset button thing on the back least that worked on mine
Mar 21, 2009 | Insignia NS-4V17b MP3 Player
I was watching TV and when the screen went black I noticed some liquid type marks. What are these? How can I fix them? Is it covered by warranty?
if your wide screen panel went out completely and wont turn on it should be covered by the waranty that is what you have to pay extra for, call the store or source you bought it from and let them know asap.
seems you have a shut down circut or a defective screen issue. you have liquid type marks on the screen itself then theres a chance it is defective, so dont wait to long to get your exchange or a waranty repair..
good luck
Dec 11, 2008 | Televison & Video
Flickering screen of my lifebook s series
This sounds like a loose connection. If you can press on the back of the lid and it flickers or stops flickering, then it's definitely a connection problem. You will need to take the bezel around the screen off, the screws are hidden under small sticky tabs or the small rubber bumpers. Then take the screen loose and check the connection on the back. Replace the tape on the cable, if there is any.
Aug 02, 2008 | Intel S6240 Notebook
Philips GoGear Flash MP3 Player Logo
334 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
