Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon Printer MP83-
I'm getting Error Code 6A00 and the printer will not operate. I have checked for jammed paper, I have ensured that the scanner button the left side is unlocked, and I have also ensured that the ink cartridges are securely in place. Do you have any other ideas?
Thanks
  • 4,041 Answers
Hi
Good luck
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Code 6A00 -
6A00 means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it.
Jun 24, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 01, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
104 people viewed this question
old marine
old marine
