Question about Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4200 All-In-One toner cartridge resetting
The machine displays the error that " toner empty" " change cartridge" and does not intialize printing as the cartridge is refilled kindly help [email protected]
  • ian78 Sep 17, 2008
    I am having the same issue. I need to find a way to reset my machine so it will accept refurbished toner.Thanks in advance - Ian
    New Friend:
I want samsung chip reset softwer ,
Posted on Dec 27, 2013
I cannot fine this printer fuser.. where can i find in this printer..
Posted on Aug 30, 2008
SOURCE:
My sharp copier ar-m201 displayed toner cartridge near empty and i refill, but still display toner, it now displyed ERROR F2-02, USER GUIDE, and do not allow printing anymore. solution please?
Need to replaced toner cartridge with oem product. there is chip in the unit that communicates with the machine. It needs to be a new one which comes with the new cartridge.
Apr 22, 2018 | Sharp Office Equipment & Supplies
Hi mi sumsingcxs6345nis tuner error
See the section on Replacing the toner cartridge in page 10.3 of the manual.
When the toner cartridge is completely empty:
• Toner Empty, Replace Toner1 appears on the display.
• The machine stops printing. Incoming faxes are saved in memory.
At this stage, the toner cartridge needs to be replaced.Check the type of the toner cartridge for your machine. (Page 12.1)
There are many well explained steps in the manual.
http://downloadcenter.samsung.com/content/UM/200810/20081010120126000_Guide_EN.pdf
Mar 07, 2016 | Office Equipment & Supplies
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 17, 2015 | Sharp FO-2081 Copier
I will refilling in toner Samsung scx 4x21 printer but display is toner empty what to do sir
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jun 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Inatallation of a printer
Hello , I believe I can help you out.
First here is a bit about your machines toner maintenance.
Second will be how to change the cartridge.
Remember if I was of assistance please be kind and leave a kind quick testimonial and good rating.
Maintaining the toner cartridge
Toner cartridge storage
Toner cartridges contain components that are sensitive to
light, temperature, and humidity. Samsung suggests users
follow the recommendations to ensure the optimum
performance, highest quality, and longest life from your
new Samsung toner cartridge.
Store this cartridge in the same environment as the printer
it will be used in; this should be in controlled office
temperature and humidity conditions. The toner cartridge
should remain in its original, unopened package until
installation – If original packaging is not available, cover
the top opening of the cartridge with paper and store in a
dark cabinet.
Opening the cartridge package prior to use dramatically
shortens its useful shelf and operating life. Do not store on
the floor. If the toner cartridge is removed from the printer,
always store the cartridge:
• Inside the protective bag from the original package
• Correct side up in a horizontal position (not standing on
end)
• Do not store consumables in;
- Temperature greater than 40°C (104°F).
- Humidity range less than 20% and not greater than
80%.
- An environment with extreme changes in humidity or
temperature.
- Direct sunlight or room light.
- Dusty places.
- A car for a long period of time.
- An environment where corrosive gases are present.
• An environment with salty air.
Handling instructions
• Do not touch the surface of the photosensitive drum in
the cartridge.
• Do not expose the cartridge to unnecessary vibrations
or shock.
• Never manually rotate the drum, especially in the
reverse direction; this can cause internal damage and
toner spillage.
Use of non-Samsung and refilled toner
cartridge
Samsung Electronics does not recommend or approve the
use of non-Samsung brand toner cartridges in your printer
including generic, store brand, refilled, or remanufactured
toner cartridges.
CAUTION: Samsung’s printer warranty does not cover damage to
the machine caused by the use of a refilled, remanufactured, or
non-Samsung brand toner cartridge.
Estimated cartridge life
Estimated cartridge life (the life of the toner cartridge yield)
depends on the amount of toner that print jobs require. The
actual print-out number may vary depending on the print
density of the pages you print on, operating environment,
printing interval, media type, and/or media size. For
example, if you print a lot of graphics, the consumption of
the toner is high and you may need to change the cartridge
more often.
Redistributing the toner cartridge
When the toner cartridge is near the end of its life:
• White streaks or light printing occurs.
• The warning message, Toner Low displays on the control
panel.
• The Smart Panel program window appears on the computer
telling you that the toner cartridge is low on toner.
• The Status LED blinks red.
If this happens, you can temporarily reestablish print quality by
redistributing the remaining toner in the toner cartridge. In
some cases, white streaks or light printing will still occur even
after you have redistributed the toner.
1 Open the front cover.
2 Pull the toner cartridge out.
3 Thoroughly roll the toner cartridge 5 or 6 times to
distribute the toner evenly inside the toner cartridge.
NOTE: If toner gets on your clothing, wipe it off with a dry
cloth and wash clothing in cold water. Hot water sets toner into
fabric
Changing cartridge:
_______________________________________________________
CAUTION: Do not touch the green underside of the toner
cartridge. Use the handle on the toner cartridge to avoid
touching this area.
4 Hold the toner cartridge by the handle and slowly insert
the toner cartridge into the opening in the machine.
5 Tabs on the sides of the toner cartridge and corresponding
grooves within the machine will guide the toner cartridge
into the correct position until it locks into place completely.
6 Close the front cover. Make sure that the cover is securely
closed.
• The printer stops printing.
telling you that the toner cartridge is empty.
• The Status LED lights red.
At this stage, the toner cartridge needs to be replaced. For
order information for toner cartridges, see page 7.1.
1 Pull the toner cartridge out.
2 Remove the new toner cartridge from its bag.
3 Roll the toner cartridge 5 or 6 items to distribute the toner
Thoroughly rolling the toner cartridge will assure
maximum copies per toner cartridge.
4 Remove the paper protecting the toner cartridge.
fabric.
touching this area.
5 Hold the toner cartridge by the handle and slowly insert
6 Tabs on the sides of the toner cartridge and corresponding
7 Close the front cover. Make sure that the cover is securely
closed.
Good Luck!
Mar 30, 2010 | Samsung SCX-4300 Monochrome Laser...
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
My SF 560PR Printer wont print and displays toner exhausted
Replace it with an original toner cartridge. That could help.
Jul 09, 2009 | Samsung SF-565P All-In-One Laser Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Samsung SCX 4200 All-In-One Laser Printer Logo
1,749 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
