Question about Sony Xplod XM-1652Z Car Audio Amplifier
1200 Watt Amp Problem
I have the same problem with my amp pulsing when i turn the key how would i fix it in good description since i am not the best with care audio
  • Anonymous Dec 10, 2008
    I have the same amplifier and somedays it works but when it does it doenst stay on that long at all.
  • John Larsen May 11, 2010
    what are you using for power and ground wire??? where is it grounded at? and what size fuse are you using??
  • 323 Answers
Make sure you are using your head-unit to increase volume and bass. May be trying to put too much through the amp.
Posted on Feb 07, 2009
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have two 12' kickers, will a x-plore 1000 watt 4 channel amp work well with it?
It all depends on the wattage of your subs. you need an amp more powerful than the both subs combined. For example. for 2 500 watt subs, you'll need at least a 1200 watt amp. amps should never be truned up to full power, 80% max as they tend to blow more quickly and overheat when on max. ideally you want an amp over the total combined wattage of your both subs so you dont need your amp on max for the best sound for you subs.
Mar 02, 2011 | Rockwood XR-3973 Car Audio Amplifier
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
Rampage amplifier
The amp is supposed to turn on and off with the head unit. The remote wire on the amp should be connected t othe amp control/power antenna wire of the head unit.
The pop should go away when the remote is being switched on with the head unit.
If the amp is staying on with the key removed, it will drain your battery. You need to re-wire it so you don't get stranded.
Nov 29, 2007 | Audiovox Rampage 1200 Watt Amplifier Car...
AMP turns ON then turns off
The power antenna wire only supplies 12vdc when the radio is on. When CD or other sources are selected, the power antenna wire goes to 0vdc. The remote turn-on wire provides 12vdc whenever the head-unit is on. If your amps are powered on only when the radio is turned on, I would bet that you have the power antenna wire connected and not the remote turnon wire.
Sep 11, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
49 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
