Hitachi 60SX12B/13K Double vision green and purple on right half of picture
    New Friend:
  • 50 Answers
If you have knowledge in electronics you can check and reheat cold solders in the chroma section and CRT board, and if it's not working do some adjustments, turn the stat it may be a trimmer or a rheostat...
Posted on Aug 11, 2008
Stk starting to go bad on hitachi tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 24, 2010 | Hitachi 60SX12B/13K 60" Rear Projection...
I have a Hitachi Ultravision TV. I have a problem with the screen like its shows double images on the screen and it has a blue or green dip from the top of the screen. The Model# 60SX12B and this was made...
its a convergence problem, unless you are experienced technician probably not a good idea to fix yourself. usually a reapair shop will charge avg 250-400 for repair
Mar 18, 2010 | Hitachi 60SX12B/13K 60" Rear Projection...
REPOST: Hitachi 60SX12B Rear Projection TV typical(?) problem
If you can solder you can Fix It STK ICs they are big black ICs will have part number on them example STK392-110 replace Both and these resistors RK42 3.3ohms RK46 1.8 RK5 2.7 RK54 1.5 RK58 3.9 RK60 2.2ohms upgrade to STK392-150s better ICs
Dec 03, 2009 | Hitachi 60SX12B/13K 60" Rear Projection...
Have a hitachi projection tv and have a double image, blue one shows up below the main picture.
Hi, your convergence circuit has failed, if you are a very proficient solderer & think you have the aptitude to remove a board from the set you can order the parts from Acme Sales in Orlando Fl. and do it yourself, if not you should call your local shops and get an estimate for the replacement of your "Convergence IC`s".
gl, video-tek
Jun 30, 2009 | Hitachi 60SX12B/13K 60" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Blue line wont adjust
you will need to replace both convergence ICs and the 6 feed resistors. If you need more info let me know
Jul 14, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
60sx12b/13k black screen
Hi, you have some poor solder connections on the sweep board, this is an inexpensive fix for any tech to do, get it soldered and enjoy, good luck & Happy Holidays
Nov 28, 2007 | Hitachi 60SX12B/13K 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
