Question about Apple iPhone Smartphone
Iphone can't restore back to version 1.4 nor can unlock
I have been agonizing how to solve the mystery of my iphone for ages. It all started when I updated my itunes to 7.7. When that got updated, so did my iphone. Now that it's updated, it got locked. So i tried restoring and there's still no solution. I tried using ziphone but halfway it goes to itunes to restore again and it keeps on repeating and restoring without unlocking I've tried reinstalling itunes from past versions and still no luck. I think I have tried every solution on my pc and it won't restore nor unlock. Could you pls advise me any other solutions? Thank you so much.
Asasa
Posted on Aug 12, 2008
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
I put in wrong code and now it says disabled connect to iTunes but I set the phone up with wifi so how do I get in my iPhone?
Your iPhone is currently on disabled mode after entering wrong combination of password. There are several ways to gain back the access to your iPhone:
First Method: iTunes
1. Using your computer, open iTunes where you have recently backed up your iPhone.
2. Connect your iPhone. Once your iPhone is detected, a notification will appear to enter your passcode. Note: If the lockscreen doesn't show, proceed to next method.
Second Method: Update
1. While your iPhone connected to iTunes, powered on. Hold down the Power key + Home button simultaneously until the screen off, keep on pressing the Home button then release the Power key until iTunes detected that your iPhone is on Recovery Mode. Note: An iTunes logo will appear on the iPhone when Recovery mode is enabled.
2. On iTunes, click on Update iPhone. It may take a while to download the software, so leave it for a while connected until the installation complete.
3. Once updated, try unlocking your iPhone. Note: If you still can't unlock your iPhone proceed to next method.
Third Method: Restore (last option)
1. If method 1 and 2 fails to unlock your iPhone. Then try to restore your iPhone into its factory default and restore your backup after.
2. Go to recovery mode. See method 2 step 1 process to enable recovery mode.
3. Then choose Restore iPhone. Note: Restoring your iPhone will delete and remove all of your data including apps, music, photos, messages, contacts, notes, etc.
4. It may take a while to download and install the software, so leave your device connected until the process complete.
5. After your iPhone has been restored, choose restore from a backup or iCloud, then wait until your iPhone successfully synced your old data.
6. Try unlocking your iPhone.
-joshd
Mar 28, 2016 | Apple iPhone 5c
How do you factory hard reset a apple iphone with the model number A1332 an no sim?
iTunes enables you to restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone with iTunes as follows.
1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
4. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
How to Restore iPhone 6 Plus to Factory Settings
Aug 28, 2014 | Apple iPhone Cell Phones
Forgot passcode
If you have forgotten the passcode on your iPhone, you will have to restore the device.
To restore your iPhone -- which deletes all of your data (songs, photos, videos, apps, and so on) on the iPhone use the following directions. Be absolutely sure that you have backed up the content on your iPhone before restoring it.
Apple's official instructions to restore an iPhone are:
1. Connect iPhone to your computer.
2. In iTunes, select iPhone in the Devices list, then click Summary at the top of the screen.
3. Click "Check for Update." iTunes tells you if there's a newer version of the iPhone software available.
4. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you back up iPhone when prompted. When the iPhone software has been restored, you can either set it up as a new iPhone, or restore your music, videos, app data, and other content from a backup.
Please also note that Apple representatives can't unlock an iPhone for you without restoring the iPhone, which will erase everything on it.
Oct 16, 2012 | Apple iPhone 3G
My daughter set a password for son's iphone 3G and she cannot remember the password, can someone advice me how to unlock the phone
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 08, 2011 | Apple iPhone 3G
IPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
Apr 14, 2009 | Apple iPhone Smartphone
Iphone
two questions:
1. Do you use Mac or PC??
2. What version is your Iphone on now? 2.2?
Dont worry as of today ANY iphone on ANY version can be unlocked.
Im pretty sure that Ziphone is not uptodate anymore.
I recommend Pwnagetool or Quickpwn to unlock/jailbreak current versions of Iphone software.
http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=1
here youll find tutorials for the iphone 3g and 2g on mac or pc =)
Aug 11, 2008 | Apple iPhone Smartphone
Iphone will restore but wont do jailbreak or unlock sim on the ziphone .
you have to re jailbreak it before you do that. eg. restore>jailbreak>sim unlock
Aug 01, 2008 | Apple iPhone Smartphone
Iphone 2.0 Firmware installed...Iphone locked
if you were using itune to upgrade to 2.0 , then use same itune to restore back to perivious version
you may also try ziphone software to restore back to old version
do let me know at jaspreet501@gmail.com what happen?
Jul 28, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
57 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
