Question about Toshiba Satellite A135-S2276 Notebook
Toshiba satelitte L40
HI, MY LAPTOP WON'T POWER UP, took battery out still dosn;t, with battery in no power, what could it be please?
    Problem Solver:
  • 6 Answers
You are having the same charging issue that many other Toshiba laptop owners are having. The power module where you plug in the AC adapter to the computer is defective. This is a known issue that Best Buy usually can't figure out. I sent mine back to Best Buy 4 times under warranty and they were unable to fix it.
If it's still under warranty tell them to replace that power plug circuit board or whatever it is and it will work fine. Mine has been working fine since Toshiba replaced that part 6 months ago. If it's not under warranty, toss it in the trash and buy anything but a Toshiba.
Posted on Oct 22, 2008
I have this particular model and the same problem has occured for me at least 5 times in the 14 months that i have had it. At this moment mine is a cold hard lump of junk! my suggestion ditch it and get something without the name Toshiba on it. I don't want to be the bringer of bad news but (it is your motherboard) and it will keep happeneing even if you do decide to get it fixed.
Posted on Aug 11, 2008
Thank you! so you don't thimk its a fault with the adaptor or battery? when i switch it on from the wall there is absolutely nothing, same happens with or without the battery installed,
  • 659 Answers
Could be a short in the motherboard. would need to be looked at by a tech to see if anything is blown.
Tecra satelitte will not turn on, orange light flashing, what sould I do
Sounds like your battery is dead. Remove the battery and plug it up does it come on?
Feb 18, 2015 | Toshiba Computers & Internet
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Toshiba Satelitte A500-17X Bios Update Fail, I was asked to update this software and then it downloaded the file and installed it. Now the laptop does not turn on
The bios is corrupted because it was not able to complete the download, or there was a power interuption corrupting the data, and finally the wrong file was downloaded. The only thing you can try is remove the main battery and disconnect the power supply from the laptop and press and hold power fot 60 seconds, then plug everything back in and try to restart the laptop, probably won't work.
Jul 11, 2012 | Toshiba Satellite P105-S6197 Laptop
How do i restore toshiba satellite pro L40 to factory ?
You can easily restore your laptop hard drive by using my partition recovery tool
Jan 15, 2012 | Toshiba Satellite L40 Laptop Universal AC...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
How to change cmos battery in toshiba l40-156
There is only one battery. If you are not familiar with toshiba (or any) laptop disassembly i recommend you get a trained and/or authorized service depot to handle this. n If you would like to do it on your own (at your own risk) you should be able to find the battery below the keyboard.
Again, AT YOUR OWN RISK.
Dec 28, 2009 | Computers & Internet
Won't turn on - no ac power not with battery no indicator lights
Hi, My Name is Henry. I am one of the technicians here.
It may be that the battery has gone totally flat and needs boosting to start charging or simply that its dead. Another possibility is your ac adaptor charge. You need to check to see that that is working.
If still not working. I suggest you invite a Laptop repair technician.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 19, 2009 | Computers & Internet
Power
You should reinstall ur battery in ur laptop and charge it for atleast 6 hours...then try to start...!
Jan 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
