Question about LG Televison & Video
LG 42P3CD has gone dark after hearing a loud click. All imputs are displaying the same darkness. Some screen updating is occuring, but it is minimal and mostly white, gray and beige colors. Any ideas on what the problem is?
5 Suggested Answers
SOURCE: Zenith 60'' LCD TV a blue screen is not sky blue it looks dark blue to black
ADVERTISEMENT/SOLICITATION FROM AN ATTORNEY REGARDING A LEGAL ACTION AGAINST ZENITH/LG If you are interested in speaking with an attorney at no cost and/or joining a class action lawsuit concerning the blue screen/haze problem on Zenith and LG rear projection LCD televisions, please contact Daniel E. Sobelsohn by phone or email: Daniel E. Sobelsohn, Esq. The Sobelsohn Law Firm 1901 Avenue of the Stars 2nd Floor Los Angeles, CA 90067 direct dial telephone (310) 461-1333 facsimile (310)861-5205 dsobelsohn@sobelsohnlaw.com
Posted on Oct 20, 2006
  • 579 Answers
SOURCE: dark bottom half of screen and dark patch in corner
Thanks for the picture - that's a big help.
It looks you have the dreaded light tunnel collapse common to all LG1.gif DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps.
Hope Ya Fix It!
Posted on Jan 24, 2008
zipeppe
SOURCE: Laptop screen gone dark
I had a similar problem on my Fujitsu-Siemens Lifebook C-1020 and I had to replace both the C/C inverter that the CCFL lamp. Easy to find/replace the inverter (only take care of input/output plugs), tricky to find/replace the CCFL lamp (because of diameter, lenght and toxic Hg content).
Zpp
Have fun!
Posted on Mar 09, 2008
  • 2072 Answers
SOURCE: color issue
Try this link
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Tekcolor correction should take care of that.
Posted on Apr 09, 2008
SOURCE: LG 50PX1D 50 in. Plasma TV
i just had the same problem. after talking to many tv repair people i finally got a knowledgeable person to help me. i ordered the part and fixed it myself.
it was very easy. i have an LG model# 50px1d. so if you had this problem i suggest you order the part yourself and fix it. i got an estimate for repair and it wouldv'e cost me at least $500 parts and labor. i paid $230 for the part. so you can see i saved a little more than half. the part you need is the " Z SUS " ASSEMBLY. you can order the part from LG website. the part # is 6871QZH044C.
let's just say after doing everything myself, i am watching TV right now.
by the way LG would not help me at all. spread the word that LG is not a good product.
Posted on Feb 07, 2009
Lg rz42px screen dark
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 28, 2012 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Our 42" lg tv is
no. there's some problem on its display circuits that it need to be corrected, picture becoming dark has some problem with the inverter power supply circuits that responsible for lighting the small lcd flourescent light. maybe some loose connection in the components cause that to happen
Feb 06, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Two thirds of the picture has gone dark on 42lg5000-za tv
    The problem actually is from a lamp in the unit, it is getting damaged gradually that is why it is two third of the screen that has gone dark. once it gets completely damaged, the entire screen will turn dark.
    Try to ***** the lamp of the television and replace it with a new one.
    After doing that your television will be in good condition once again.
    Take care and good luck
    Oct 23, 2010 | LG Televison & Video
    I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
    There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
    Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
    Laptop dark screen
    After updating the BIOS the screen has gone dark...What you can do is perform a forced shut down and then unplug the A/C Adapter pin and remove the battery and then press the power button for 30 secs then place the battery in and then connect the A/C Adapter pin and restart the system...It should work...If it does not then please let me know i will tell you the next step what we need to do
    Aug 16, 2009 | Computers & Internet
    Totally dark scree!!!
    sir, it think the problem is only with the display of your mp3.since you are able to listen to the music, i think you need to change the display of your mp3. it will be available in any reputed mp3 store.
    May 28, 2009 | Creative Labs ZEN V Plus MP3 Player
    LG Shine screen display
    replaced the LCDS on the phone
    Aug 19, 2008 | LG KG800 Cellular Phone
    Televison & Video Logo
    122 people viewed this question
    Henry  Thomas
    Henry Thomas
