Question about HP Office Equipment & Supplies
Just bought a officejet pro L7555 not listed on cd setup
  • 659 Answers
How to fix a hp printerl7555 that is off line
Hi
first ensure that you are connected, the cables.
if you have it right, install the drive again. PC sometimes because of the update of the driver lose divices.
Sep 01, 2014 | HP Ink for OfficeJet Pro L7555
My HP Officejet L7555 will not scan to my Notebook Laptop problem. I have tried to download HP Solutions Center wiyh no success. When "Scan" or "Start scan" is depressed on my L7555 printer, the printer...
How is the HP Officejet Pro L7555 connected to the computer? Can you manually launch a scan from the computer using the HP software?
If you can start a scan from the software, you may need to set the software to listen and respond to the all-in-one's buttons. In Settings, choose Scan Settings. In this menu, select Scan To Setup. Add the needed buttons. Click Update device and set the scan quality/destinations. Save this. If these short-cuts are available in the HP Solution Center, check if the monitoring software is set to run automatically. If the monitor is closed, you will need to launch it.
If you can't launch a scan from the software manually, then your computer and the all-in-one are not communicating properly. Scanning requires bi-directional communication. If the connection involves a USB cable, try a new cable. Try a direct connection if you are using a USB hub. For a network connection, check your firewall (inbound and outbound traffic). Resetting the firewall will depend on that software. Check that you have the current drivers. Consider using the HP diagnostic software to check for problems.
I hope this helps.
Mar 05, 2018 | Computers & Internet
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
REads remove and check cartridge
Oct 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
  1. Open the HP Director/Solution Center software.
  2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
  3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
  4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
    Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
Causes:
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
regards,
coffeebeans
Mar 15, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
