Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Display for about i second then black screen
Gets display then goes black. no image when using flashlite at angle
Yea, u gota set it at 1024x768 at 60hertz, i kno uit sux, if it goes to any other mode it dont work, i hate that
Posted on Aug 27, 2008
    Scholar:
  • 39 Answers
Your Monitor might be shot. I would recommend you try another VGA Cable and 3 prong Power cable since it could be the cable as well . If you are still experience the image going black then the power inverter internally could be damaged and its not as easy as a simple backlight because if you are using the flashlight and no image is showing you are worse than I thought. I would recommend you try those two things and then also if you can try to connect it to another Computer who knows it could possibly be your desktop too like the video card going bad ?. If you dont have another computer try a laptop or a TV with the VGA option on them. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Posted on Aug 11, 2008
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
Apr 20, 2012 | Dell UltraSharp 2407WFP 24" LCD Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Samsung T220 Screen Flicker
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Computers & Internet
Monitor Display
There is no virus that can damage the monitor. This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 26, 2008 | Smart Modular SV3170A
Monitor displays for 1 second when PC is turned on then goes black. If I turn the monitor off then on again, it displays for 1 second. HELP!!
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 18, 2008 | ViewSonic VX900 19" LCD Monitor
Image appears for 2-3 seconds then screen goes black
The following steps are how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 15, 2008 | IBM ThinkVision L170m (Black) Monitor
My screen has been going black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After went black, you have check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Mar 05, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
