Need information on a philips t.v. model 32PT6441/37
It's always turned back on when turned off. Tonite, it stopped working with the remote and a capital letter (F) come up on the screen in the top right corner in the orange sq. where mono will show then it turns to this letter (F) What does this mean and how do you fix it. The remote will not work it anylonger, new batteries in it. I need a manual for this model t.v.
  • 4 more comments
  • bessylou4 Aug 12, 2008
    My Philips Energy Star T.V. Model No. 32PT6441/37, Serial No. YA1A0521806249, has stopped working along w/the remote control that came w/it when purchased. An(F)appears in the top right corner of the t.v. I learned this means that the t.v. is in a factory mode. 1. How do you get the t.v. out of this mode? 2. Why doesn't the remote control work any longer on the t.v.? 3. How do I repair all this? I purchased another remote control, a "Universal", from Wal-Mart. It didn't work either. Couldn't get it set w/a code to work w/t.v.
    Please give me some solution to these problems. I purchased this FixYa for $9.99 tonight. Put the purchase on Pay Pal. I still haven't got my problem resolved. I found, then downloaded the manual for the model t.v. but, no info. on the(F)"factory mode" problem.
    Also, Ever since I've owned this t.v.,it turns itself back on after I turn it off. 4. What is causing this?
    Please reply ASAP, by e-mail or by phone.
    Thank you,
    bessylou4@yahoo.com
    Betty Phone: 1-918-775-8590
    P.S. How do you use this FixYa Program. I got a reply from the above message. He was telling me to go to the FixYa Program, that it's the best online for problem solutions. O.K. I've done this and now I'm trying to get my whole message to one of these repairman, showing up in the top right corner of this program. I don't know if anyone is or has received my posted message or not. I'm totally confused.
    bessylou4@yahoo.com
    To Mastersaintx, When I said the remote control don't work any more, I mean, it doesn't turn the the t.v. on or off, don't change the channels, doesn't do anything to the t.v. It's just like the remote control has dead batteries in it, but, I've put 2 sets of new batteries it the RC and it still doesn't control the t.v. at all. That's what I meant by that statement.
    Also, on the Universal control. I tried to code in the codes on the manual that come with it, but, nothing either. Just like the original RC that came w/the t.v. when purchased back in 2006.
    I appologize for the last comment I made about not being able to get in touch with any repairman, but every time I clicked on the My Profile, it showed, "not available". I was getting very upset and finally, I tried it the 4th. time and your solution come up. Thank God.
    I will try this and if it doesn't work. I'll try again.
    Thank you, bessylou4@yahoo.com member of FixYa.com (I guess!!!! )
    To Mastersaintx, I don't have an A 24 on my RC. I pressed 2 and 4, turned it off, unplugged it for 10 seconds, then, turned it back on and the F is still on the top right corner of screen. On the Universal RC, it has an ABC button, so, I pressed it then, 2 & 4, turned it off, unplugged it, counted 10 seconds, plugged it back up, then turned it back on and it's still in factory mode.
    bessylou4@yahoo.com
    To Mastersaintx, I don't have an A24 on my RC, So, I pressed 2&4 then did everything you said to the letter and nothing, the F is still on the screen. The Universal RC has an ABC button, so, I pressed it then 2 then 4 did everything again like u said and it's still in factory mode.
    Where do you come up with this A24 at?
    Ajkill, I owe u a big thank u. At first, I didn't understand your (-) signs but, I just starting pushen & pressen buttons on top of TV. The dummy here, finally got a menu & then I was home free. Your solution worked. I'm amazed at the knowledge of all Electronic Professional Repairman. Thank U Again. Your "Good Luck" comment was in order.
    bessylou4@yahoo.com
    Member of FixYa.com
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
need information on a philips t.v. model 32PT6441/ - clip_image001.jpg
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Aug 12, 2008
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Aug 21, 2008
    To disable the Demo mode, perform the following:
    1. Turn on the TV.
    2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
    3. Hold for about 6 seconds
    4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
  • LORETO LACARON
    LORETO LACARON Aug 26, 2008
    Latest updates of the problem!!!
  • LORETO LACARON
    LORETO LACARON Aug 30, 2008
    Genius:
  • 1,665 Answers
To enter the factory service menu on most philips sets.
With the remote. Press 062596 ->status This will take you to the regular setup menu.
With the remote. Press 062597 -> status This will get into the
convergence menu.
http://www.usersmanualguide.com/philips/tv__4_3_-_tv_extra_large_29_inch_and_above
    Brigadier General:
  • 6,966 Answers
The "F" as you describe as factory mode is actually the Service Mode. You can exit this mode by pressing on the power button to turn unit off. Which brings to mind, how did it enter the service mode in the first place which requires a 7 button sequence.
If the above is not corrective, pls try a hard reset, unplug the unit from the mains. Worst case scenario would be a DIY (do-it-yourself) on the logic circuitry or seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 2,035 Answers
  1. When a letter F appears on the right hand corner of the screen means the television is in factory mode.
  • When a letter F appears on the right hand corner of the screen means the television is in factory mode.
  • To exit from factory mode, press the ‘VOLUME (-)’ and ‘CHANNEL (-)’ buttons on the TV set simultaneous for 5 seconds.
And check if any sleep timer is activated on the tv ....
Good luck...
  • Anand Kumar
    Anand Kumar Aug 12, 2008
    I am glad your problem is solved ,Please rate my solution ........
    Thank you..
  • 928 Answers
On your remote control you have to select A24 then turn off the TV. Unplug it for 10 seconds then it should be fine.
When you say your remote control does not work may I ask what you mean by this? When you press anything on the remote, nothing happens on screen any longer?
As for the universal remote you can look at its manual and look for the code for Philips then input it on the universal remote so that it will work with your TV then you can use the A24 option to exit out of factory mode.
    Master:
  • 848 Answers
Can you provide your model number ......
I have an old JVC TH-p7 home theater system. My remote control stopped working. I have an Philips universal remote control, but I can't find the code needed the TH-P7
If you cannot get the Philips to work you could always look to purchase another JVC remote that is compatible with the TH-P7. I believe that the remote model# is JVC RM-STHP7U. You can find the replacement remote by using the remote control search engine below. Here are the search results for the JVC RM-STHP7U:
http://ezremotefinder.com/results.php?mfg=JVC&mdl=RM-STHP7U&keywords=&page=1
Jan 31, 2016 | Philips Audio Players & Recorders
We have lost remote for philips tv
sure...we'll just need the model number of your TV to make this happen..can you supply that soon?
Feb 26, 2008 | Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
CAN'T TURN ON MY PHILIPS 42FD9925/01 SCREEN, ALWAYS IN STANDBAY
Did this solution work as I have the same model and same problem and I have ordered the remote from philips suppliers
Jun 20, 2009 | Philips 42FD9932 42 in. Plasma Television
Need instruction book
I was unable to locate your specific model using the information you provided however here is a link to the Philips website.
http://www.support.philips.com/support/html/index_us_en.html
They have a diagram to identify exactly which numbers they need to identify the appropriate manual. From there it should be a simple download to get the information you need.
I hope this helps, good luck!
Kym McC
Oct 11, 2008 | Philips Magnavox Learning Universal Remote
PROBLEMS AS DESCRIPTION BELOW
Ajkill, a FixYa.com repairman, was the one who e-mailed my solution. He told me to go to the top buttons of the tv, the Volume (-) & Channel (-) buttons and press them simultaneous. I did this, not really knowing what to expect. I then got a menu. I scrolled down and across to select the tv setup I wanted, then the factory mode finally disappeared. The tv then started working with my remote control again. Thanks to Ajkill and the Good Lord.
P.S. I want to edit the sentence above, in green, where its stating: "It's always turned back on when turned off". I don't remember typing this. I meant to say there, that the tv turns itself back on, some times, when I turn it off. If anyone out has a solution fix for this, then, please let me know.
Thank you,
bessylou4@yahoo.com
A New Member of FixYa.com
Aug 12, 2008 | Televison & Video
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Sep 12, 2007 | Philips 25PS40S 25" TV
TV PROMO COMES ON.
As far as I know you need the remote to turn off the promo but try the store first where you bought it or try this addy. http://www.usasupport.philips.com/caseSu... or this # 1-888-PHILIPS. If they tell you you need a remote Go or http://www.remotes.com or call 1800- remotes Good Luck
Jun 21, 2006 | Philips TP2797B 27" TV
Televison & Video Logo
315 people viewed this question
Top Televison & Video Experts
