Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark 7100 Printer - Incorrect Cartridge
Hi
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears.
Have turned off on. Removed power source. Taken cartridges out and put back in - no luck.
Any suggestion would be apreciated.
Thanyou
  • 3 more comments
  • Anonymous Aug 24, 2008
    same problem. now display says right cartridge is incorrect but it's the correct one. suggestions appreciated
  • sanjivnaik Nov 04, 2008
    I always refill my cartridge. This time the error says " right cartrigde incorrect". What to do?
  • Anonymous Jan 01, 2009
    I am having the same problem
  • sibley40 Feb 08, 2009
    Just changed the low black cartridge now says the right is incorrect.
    Same problem.
  • Anonymous May 11, 2009
    I have the same problem as well.
2 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: Recently had a low toner
Nice job on trying different ways to resolve the problem - turning off/on the printer, removing power source, reseating the cartridges and even changing the cartridge with a genuine Lexmark cartridge. You pretty much did the necessary. Genuine Lexmark cartridges shouldn't cause you that much trouble. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Posted on Sep 01, 2010
Why does my lexmark x5320 keep saying left cartridge is incorrect?
It is very likely the ink cartridge is defective, i would suggest you remove it an few times and then reinstall it, if the message still appears replace the cartridge.
Feb 06, 2012 | Lexmark X5470 All-In-One InkJet Printer
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
Recently had a low toner message for black. Next time I went to use a fault appeared - incoreect cartridge. I replaced black toner with genuine Lexmark cartridge - message still appears. Have turned...
Sep 01, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Lexmark error: 33.64
Change Toner cartridge.
Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
Maxi
Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
478 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
