Question about Motorola Mobility E815
How do i take it apart?
I took the 4 screws out of the back of the phone but I don't know how to get the phone to come apart, i'm guessing there's a holding clip on the plastic but i don't know where it is or how to pop it apart. Help is appreciated! Thanks,
Carter need to take apart a verizon motorola mdl. e815 to put a new dial pad back in and need the instructions how?
  • 66 Answers
You have to pry out the rear bottom cover with a plastic tool. that will reveal twu other screws to complete the dissasembly
Posted on Nov 22, 2008
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
Vacuum smells and is not picking up well. Took the pole apart and I don't know hao to open the bottom.
To get into to the bottom of the vacuum, flip it to where you can see the bottom of the baseplate. Only unscrew the recessed screws...4 to 5 screws. Once you have removed those, the basepalte will pop off. It is probably just clogged at the bottom.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
How do you take apart a gateway zx4800-06 all in one computer to put a new hard drive in. I took the case screws off but the cover won't budge and I don't want to take a chance of damaging...
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Aug 12, 2011 | Gateway ZX493131e Notebook
Sony vaio aw11m- took it apart now cant put back
You need a technician to reassemble it. There are no diagrams detailing every screw.
Good Luck!
Oct 30, 2009 | Sony VAIO VGN-AW110J/H 18.4-Inch Laptop...
Dropped the phone in the water. How do I get it apart as much as possible to dry it out b4 turning it back on? tookout the 4 screws already.
Helps to know what phone it is. Most snap together. You can pry them apart with your thumb nail or a small screw driver.
Aug 04, 2009 | Cell Phones
How do i take it apart.
using your fingernail, there are multiple plastic clips that should pop off as you run your finger around the edge, let me know if you still can't get it, you may also try a small flat headed screwdriver to pry it apart.
May 12, 2008 | Samsung SCH-u340 Cellular Phone
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Mic not working.
It worked well for me too! Thanks!! I was told I had to buy a new phone because the microphone went back. Took the receiver apart (4 screws in back of handset and 2 that held the board in place), cleaned mic with alcohol and a q-tip, and removed the rubber piece that kept the mic clean (inside of the housing), and presto, it worked just fine. The ribbon cable came loose upon opening up inside of phone, but I stuck it back inside the top of base and I was ready to go.
Oct 29, 2006 | Uniden DCT646-3 Cordless Phone
Motorola Mobility E815 Logo
246 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
