Question about Dacor MCS130 Millennia Electric Single Oven
Oven light I have 2 of these ovens from 2002.  The oven lights have begun turning on and off constantly in both of them.  I keep the fuse to the ovens off because the lights going on and off, whether the oven is in use or not, drives me crazy. Same exact problem - oven light keeps turning itself on and off intermittently. More recently, it is doing something new -- when the oven gets hot, the light switch makes a gosh-awful rapid ticking sound that is driving us batty! Can anyone offer a solution?
  • ageprof Aug 15, 2008
    The only way to stop the constant clicking noise is to push the light switch and hold it in. This, plus the other symptoms, makes me think that there is a problem with the switch that controls the oven light.
    Can someone tell me whether it is possible to replace the switch without replacing the entire control panel, and if so how I would find the part number? Is it difficult to do?
    Thanks.
  • wjrob Sep 29, 2008
    We have the same identical problem w/ the oven light. Ours is a single convection oven but I can't find the model #. It also was purchased around 2001- 2002. Any solutions
    Master:
  • 521 Answers
Thermal Fuse, or Thermal Cut Off (TCO) that is likely to be the culprit, (part # 4451442) via eBay ($29.55 incl. shipping)
Posted on Aug 15, 2008
  • tech expert12 Aug 15, 2008
    for noisy fan motor bearing is worn.pls check that.
    about switch you cannot replace manually you have to call technician compulsary.the cost will be not more then his service charge.thanks
    Guru:
  • 1,894 Answers
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Posted on Aug 11, 2008
  • dewan nafees ahmed Aug 11, 2008
    The oven light is usually a standard 40 watt appliance bulb.
    First, remove the cover and check to make sure the bulb is not loose.
    If it's loose, tighten it. If yours has stopped working completely,
    change the bulb. If this doesn’t fix the problem, then the
    problem may be with the door switch on the oven’s frame, the
    socket itself, or a separate switch by the main controls. If the switch
    doesn’t work, or only works sometimes, you need to replace
    it. If your oven has a self-cleaning feature, the oven light may not
    operate during this time.
Erratic temperature on Viking oven
What is the complete model number of your unit?
Feb 18, 2013 | Ovens
I have a MEW6527DDS built in oven. This all happens when the oven is NOT in use: The fan goes on and off, sometimes for a second, sometimes for 10+, ALL.DAY.LONG! The 'click' sound you hear when...
Wow deffinately sounds like the control brd it sounds like a pretty good examination by somebody that is used to electric.It would be a very complicated troubleshoot over a message brd.The temp problem could be calibration issues or a bad thermistor not reading to the oven correctly.but intermittent kicking on off could be more.Maybe some programming issues usually shut the power off and back on to reset but if your turning off the breaker that would rule that out.Maybe turn of power and chek plugs and wire for loose connections.that would be a good start.
Apr 25, 2011 | Maytag MEW6527DDS Electric Single Oven
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Kenmore electric oven light will not turn off.
the internal pressure switch is stuck in position. its due to surface gunk build up. carmelization of oven debris.
Feb 14, 2009 | Ovens
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Oven light
The touch membrane is gone. You can replace it (like i did) and wait for the next thing to go wrong. Took me 3 months for the next problem, and the membrane was $300.
Dec 04, 2007 | Dacor MCS130 Millennia Electric Single...
Dacor MCS130 Millennia Electric Single Oven Logo
471 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
